fixedit
- Feb 10, 2006
- 27
- 3
- 3
- VE II Calais V Redline Wagon
I have a VY with climate control and the fan only worked on maximum speed. This is typical of when the Fan or Blower Speed Resistor or Controller part fails. The most amazing thing was it failed because a wire soldered to the outside of the unit had become unsoldered and I simply resoldered it. Fixed!. Don't know if this could be the case for other models but here's the steps:
1. Open glovebox.
2. Pull glovebox down past the rubber stoppers or you can slide the stoppers out.
3. Remove glovebox by pulling out of retaining clips at back. Very easy.
4. Resistor is on right hand side with wiring connector at back.
5. Unclip wiring connector.
6. Undo two screws one on either side.
7. Slide out - it sits inside one of the ducts.
8. Check the wire on the side is still soldered. If not re-solder. If still intact, suggest you get a new one.
9. Reinstall in reverse order.
1. Open glovebox.
