Results 1 to 3 of 3
Thread: Undoing fuel lines at the firewall
    VK Berlina, VS Equipe Wagon
    Aug 2007
    Brocklehurst Heights
    Default Undoing fuel lines at the firewall
    G'day
    There was a question on the VT forum about how to disconnect the fuel lines on the ecotec that run to the firewall from the fuel rail.
    There is a special tool to use, that you can get a kit from supercheap or repco around $15, but what if you dont have one of those handy, or just don't want to spend $15.
    I made a tool out of some plastic pipe that I found in my junk heap. It was a piece of beer hose from a pub.
    The pipe has to have a 2mm thick wall and an 8mm inside diameter. The beer hose had a 10mm inside diameter, so I sliced a bit out of it lengthwise.
    I cut a piece 20mm long and clipped it over the metal fuel line.
    I pushed it in and it worked great.
    Remember you need to de-pressurise your fuel system first before attempting to remove lines by removing the fuel relay and running car untill wont start. Also it is a good idea to blow the connectors out with compressed air to remove any dirt build up.
    I made a mess of the fuel lines in my VS by not knowing this. All fixed now.
    Regards
    Chris
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    commodore vz sv6
    Sep 2010
    bundaberg
    thanks mate i needed one
  1. Undoing fuel lines on Ecotec
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 09:14 AM
  2. Undoing Cooler Lines
    Last Post: 15-11-2008, 11:46 PM
  3. VS Fuel Lines, where to buy?
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 08:02 PM
  4. how do i take my fuel lines off
    By MON57A in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 12:55 AM
  5. VR 3.8L SII Fuel Lines
    By rSharwood in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2005, 11:55 AM
