Results 1 to 2 of 2
Thread: Removing VT-VX steering wheel
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Default Removing VT-VX steering wheel
    Tools and Parts:
    -5/8" socket piece with a good socket wrench or breaker bar
    -flathead screwdriver
    -T30H bit (T30 hollow point torx bit)
    Steps:
    1. Disconnect battery
    2. Remove airbag fuse
    3. Disconnect airbag wiring harness from under dashboard (optional)
    4. Remove the 4 torx screws from the back of the wheel to release the airbag and remove it slowly.
    5. Keep the airbag facing away from you and slide you flathead screwdriver under the yellow airbag connector and pop it out.
    6. Remove the airbag and place it in the open, out of sunlight, face up and away from static sources.
    __________________
    no longer a hoon by association - the commodore is gone
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    looking to do this on the weekend, do you have to be very gentle with it? if your too rough will it go off?
  1. Guide to removing vy/vz steering wheel
    By Lumps of cheese in forum Holden Commodore How-To's
    Last Post: 14-04-2012, 02:12 PM
  2. Removing Steering wheel.
    By corkabro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2009, 11:48 AM
  3. removing steering wheel???
    By drewh7187 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-09-2007, 09:41 PM
  4. URGENT: Removing VN Steering Wheel?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2007, 02:58 PM
  5. help removing my steering wheel
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2005, 02:30 AM
