Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By TMM
Thread: Cleaning Frosted / Dirty Headlights
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Default Cleaning Frosted / Dirty Headlights
    If you are sick of your headlights looking frosted and crap here is a simple little How To in order to clean them up a bit.
    Tools / Products:
    Screwdriver
    Socket set / shifting spanner
    Glass Cleaner/ similar product
    Maybe some glue/ silicone
    Step 1:
    Disconnect the battery
    Step 2:
    Undo the 2 top bolts and the one behind the grille.
    You may find it easier if you remove the grille to make it easier for yourself, but it is not necessary.
    Step 3:
    Unplug the Loom on the back of the light and unscrew the screw which holds the indicator to the headlight.
    Step 4:
    Once you have the headlight removed from the car you can remove the clips which hold the glass lens to the back of the headlight, these clips are shown below, Note there is 4 on top, 4 on the bottom, and 1 on each side of the headlight.
    Step 5:
    Now you can remove the glass from the headlight assembly, this may require a little force depending how strong the seal is. Once off the glass cover should have the seal on it, or if it was anything like mine, half on it. but we'll fix this later, you might as well pull the seal off if it is already falling off.
    Step 6:
    Now we can clean up this thing, its not a bad idea to run it under the tap first just to wash out any dirt and duct that has collected over the years before you start spreading it around with a cloth...
    Step 7:
    Attack the inside the the glass cover with whatever you use for window cleaning, i used some cheapo foam glass cleaner that came in a can, once sprayed around evenly, use a microfibre towel or similar item to wipe off the excess cleaner on the light making sure you remove any marks or stains on the glass.
    PLEASE NOTE: The following parts may ruin your reflective surface if you use certain products.
    Step 8:
    If you want you can clean the chrome relective surface around the headlight but be warned, due to the age of modt the lights this will be very weak and may already be peeling or flaking due to age, also using the wrong product may cause the reflective surface to be stripped away.
    With my lights i just used a microfibre towel to carefully wipe away dirt on the reflective surface lightely, and i even noticed it peel at 1 point so be careful if you choose to do this.
    Reassembly:
    Step 9:
    If you had the same problem as me and the rubber seal came off the glass lens you will need to reattach this, the way i did this was by putting the seal back in the headlight assembly (not on the glass cover) and i then lightely covered the seal with gasket glue, other products may also work.
    Step 10:
    Place the glass cover back against headlight assembly making sure it contacts the seal all the way around, you can now begin to reattach the clips, i found it was easier to start from the bottom, then do the top, then sides. the clips will require some force to go back on, if you cant force it using your hands, use a flat head screwdriver to pry them over.
    Step 11:
    Place the headlight back into the car and redo the bolts and screw. make sure you remember the screw that hold in the indicator otherwise it will fall out, (i know from experience, lucky the loom held it onto the car) Now reconnect the looms, stand back and admire your work.
    Old and Busted:
    New Hotness:
    The Black Beauty
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Very nice. Looks heaps better. I was kinda thinking that it wouldn't do much, as these are glass headlights, not plastic. But wow! looks like new again. Now cleaning my headlights is on my to do list.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Unless VP is different, theres 4 bolts to take the headlight out. The two main ones, then two littles ones (one you have pointed to) and the other is near the indicator.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    i have a thing there but it didnt have bolts on it, maybe mine came off sometime in its life
    The Black Beauty
    Dave Q is offline Lumina
    VZ Lumina
    May 2009
    Good stuff TVR.
    Ive been wet-sanding and polishing up the headlights at home recently.
    Luckily I dont have really old cars so I am not worried about peeling but I am getting some outstanding results with the different sand paper and polish. There are videos on YouTube.
    Just remember that the headlight and the sandpaper has to stay wet at all times.
    You change through the grades of sandpaper until you get to 2500 grit. The lights look ugly, scratched and cloudy for a time...but dont panic. The water turns milky white as you rub ( very gently) away. It can take a long time to rub the stuff away, you have to be patient.
    Then you apply the cutting polish. I am using a stock orbital polish and a cheap polish machine. I finish off with a microfibre towel.
    If its still icchy, keep polishing with the cut.
    I dont know if some lights are unsutiable, sand and polish at your own risk.
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    I just did mine and they came great! Mine had one bolt on but the other only has the bracket and stud but the bolt seemed to have vanished lol.
    Vy Sv8
    Jun 2009
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    i never bothered looking at vr/vs headlights but if they are glass it should be very similar to this method
    The Black Beauty
    roverman88 is offline Love my Commodores :)
    88 VL Calais - 90 VN Com S Pac - 75 TX Gemini Coup
    Jan 2009
    St Albans Park, Geelong
    hey lm just wondering how did you remove the clips from the top of the light?
    CALAIS94 is offline Banned
    calais
    Feb 2012
    australia
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Old thread but worth replying to
    Quote Originally Posted by TVR-190 View Post
    does it work on glass headlights?
    Stone chip/scratch removal from glass is far more involved than plastic.
    DIY: Fog Light Sanding/Refinishing with Pics - The Unofficial BMW M5 Messageboard (m5board.com)
    Here's how my VY Fogs turned out after following the above guide:
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Quote Originally Posted by roverman88 View Post
    screwdriver to pry them off
    The Black Beauty
  1. VT headlights hazy and need cleaning - help!
    By lordmuz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2010, 03:16 PM
  2. Question About Frosted Window Tint.
    By djmenow in forum General
    Last Post: 05-02-2009, 06:03 PM
  3. dirty dirty rear end
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 04:44 PM
  4. frosted clear vr/vs tail lights
    By hakhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 10:15 PM
  5. Dirty
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2005, 06:28 PM
Tags for this Thread
