I wasn't too happy with the so called "premium" 11 speaker sound system in my Calais V so have been researching simple (and cheap) improvements.
Its surprising how little a number of specialist car audio places know about these systems (I rang 8 places).
On another forum, a guy mentioned the "gain" control adjustment that is on the Amp that is in the boiot of the Calais V and SS V.
The Amp is for the Sub woofers only. Apparently if you adjust it too high it can cause distortion. I adjusted mine from the standard "half-way" mark up to about the 5/8 position.
To do this I removed the bracket and Amp so I could see it , but you don't need to do this. You can feel the knob on the bottom edge of the Amp. Just turn it clockwise a small amount. The knob sort of clicks into its orginal "half-way" position, so you can easity return it to this spot if you want to.
Ideally get someone to sit in the car and listen to the difference as you do it.
For anyone who doesn't need a huge high cost system its definitely worth doing. The Base sounds better to my non-expert ear.
I may also replace the standard speakers with better quality but not sure.
Here are photos of where I found it and how I adjusted it:
Amp near battery:
[IMG][/IMG]
Amp label:
[IMG][/IMG]
Gain control original position:
Gain control new postion:
Have fun,
Calais57
Gday mate, do you know if its the same with the SSV ute?
Sorry mate,
not sure what is in the ute.
All I did was remove the tire well cover and stuck my hand under the side trim, 1 minute.
2009 Liquid Red G8GT
4 door mafia
93 octane VMS ecm/tcm tune
Nope.... If you can find them on my mate's SSV ute then I owe you a carton of beer... or 10!!
The SSV ute page (http://www.holden.com.au/vehicles/Ut...eries/features) doesn't even mention the number of speakers, whereas the SSV sedan info (http://www.holden.com.au/vehicles/Co...ition/features) does.
Ute:
Now even the longest drive can be an uninterrupted soundtrack, because the 6-disc CD player plays both normal CD tracks and MP3 files.
Sedan:
Now even the longest drive can be an uninterrupted soundtrack - the SS V-Series comes complete with 11 speakers including sub-woofers and a total of 230 watts 6 disc in-dash MP3 compatible CD player with auxiliary input jack and illuminated steering wheel controls.
Hey wondering if you could shed some light on exactly how to remove the amp/bracket.. It's being a stoubern little prick and not coming out :/ (note: I can't twist the knob by reaching under)
my 2010 series 1 ve ssv ute has the two subs behind the seats as well as amp,this came standard..
Thanks for the info mate , will try it out asap![]()
Done! Thanks for the tip and didnt have to remove it from the bracket either. Just used a small mirror and a torch to see it, turned it just like in your pic and it makes the bass that little bit more noticable at normal listening vol. Took 5 min to do.![]()
yes the ve ssv utes have 2/8" subs behind the seats if you have preium sound as an extra. but amp is not located with battery. did anyone ever work out where it is? im trying to find it on mine
