Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Reply
LinkBack Thread Tools Display Modes
  #1
Old 29-06-2005, 03:34 PM
Ride: N/A
Ed74mnd Executive
Default Fuel doors electric release?
Hi there,
i grafted a commodore (VL) fuel door into my FE Holden wagon.
this was great until I snapped it off.. why are these things so flimsy? and y was i dumb enough to use one!!!
anyway, I wanted to ask if there is a fuel door I can use with an electric release... if so, which models commodore have them.
I will get one from the wreckers.
Cheers for your help.
Ed
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 30-06-2005, 08:44 AM
Demons1964's Avatar
Ride: VY Calais, WHII Statesman V8, VC L 202
Trade Rating: (0)
Demons1964 Calais
I don't think there's any that have an electric release. Everything up to VK was non-lockable - no cable at all. VL-VS are all definitely cable operated. VT onwards I'm pretty sure are all cable operated (my 2002 Statesman certainly is). Have you thought about grafting on a commodore boot release solenoid onto the fuel door? Would obviously require a few modifications but it would achieve what you're after.
  #3
Old 30-06-2005, 08:51 AM
Rovert's Avatar
Ride: VT Executive Wagon
Trade Rating: (0)
Rovert Executive
I'd go the VT cable release...
  #4
Old 30-06-2005, 10:19 AM
Ride: N/A
Ed74mnd Executive
that's a shame.. the JR-JS vectra I found out have an electric release but these are hard to come by from a wrecker.
BUT>.. heaven forbid Ford Falcon has an electric release.
i may try the F&%D item and see how it fits up.
Thanks for the info, will post pics when I get it going if anyone is interested.
Ed
  #5
Old 14-07-2005, 09:40 PM
Ride: VT Berlina S2 V6 + VZ Acclaim Wagon
Trade Rating: (0)
BerlinaBen Executive
I havent seen what the elctric fuel door releases look like, but I would be very careful how you do it. Keep in mind that solenoids/relays/switches all produce sparks when they operate, which can be an issue around fuel vapours. I would assume the solenoids used for this purpose are fully sealed so make sure you use the genuine item. Dont use a boot release solenoid or anything similar. It will probably blow the door off. Just thought I should mention this.
  #6
Old 15-07-2005, 02:33 PM
Demons1964's Avatar
Trade Rating: (0)
Demons1964 Calais
Has been done before with an EA-EB Falcon boot release solenoid installed into a VN (another forum has a good how-to) where the solenoid ends up getting mounted under the parcel shelf inside the boot with wiring running alongside the rear lighting harness. The fact it's mounted in the boot (far enough removed from from vapour hoses from the fuel tank) it would be safe. Otherwise all solenoids for boot releases would be illegal. Having said that, drilling mounting holes in the parcel shelf may well make the modification illegal anyway.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
electric Boot release 12000 VN - VP Holden Commodore (1988 - 1993) 2 02-02-2007 08:55 PM
vx cable release for fuel cap cover mikespurr VT - VX Holden Commodore (1997 - 2002) 0 20-03-2006 02:42 PM
vx fuel cap cover release cable mikespurr General 0 20-03-2006 10:18 AM
I need the small tool used to release the high pressure clips on a VT fuel pump...... speedotom Holden Commodore Part Numbers and Descriptions 3 30-01-2006 08:32 PM
another electric boot release queastion TAILS83 Electrical Wiring / Questions 3 03-07-2004 09:53 PM
Web Games | Music Downloads | Pacotes TurĂ­sticos | Tools and Equipment | Dutch Bodybuilding Forums | Car Reviews
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
