Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 30-04-2004, 09:50 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default vt codes
12 Engine Speed Detection No RPM Input
(Normal when Engine is Not Running)
No Crankshaft Reference Signal
(Check Wiring, DIS Module, Crankshaft Position Sensor)
Note
Does NOT illuminate the Powertrain Checklight
13 Oxygen Sensor (Right bank) No Input Signal
Check Oxygen Sensor, Wiring or Connector
14 Engine Coolant Temperature Sensor Voltage Signal LOW
Temperature Sensor
Note
See Engine Coolant Temperature Sensor
15 Engine Coolant Temperature Sensor Voltage Signal HIGH
Temperature Sensor
Note
16 Engine Coolant Temperature Sensor Voltage Signal Unstable
Temperature Sensor Open or Short Circuit (Intermittent)
Wiring or Connectors Open or Short Circuit (Intermittent)
Note
17 Powertrain Control Module Engine Coolant Circuit.
Failure of PCM Circuit Resistor
Note
18 EGR System (Non Supercharged)
Incorrect Gas Flow
EGR Valve Problem, Wiring or Connector
Note
19 Throttle Position Sensor Sensor Jammed
Mechanical problem with Throttle Position Sensor (Broken Internal Spring)
21 Throttle Position Sensor Voltage Signal HIGH
Circuit possibly Shorted to Voltage
22 Throttle Position Sensor Voltage Signal LOW
Circuit possibly Shorted to Ground
23 Intake Air Temperature Sensor Voltage Signal HIGH
Sensor Faulty, Wiring or Connector
Note
24 Vehicle Speed Sensor Automatic Transmission
Signal Input Unchanging (While decelerating)
Note
25 Intake Air Temperature Sensor Voltage Signal LOW
Note
26 Intake Air Temperature Sensor Voltage Signal Unstable
Sensor Faulty, Wiring or Connector Intermittent
Note
29 Exhaust Gas Recirculation (EGR) System: Pintle Position Fault
(EGR Position Sensor inside the EGR Valve)
Pintle Jammed
EGR Valve Failure
Note
31 Theft Deterrent System: No Signal
(Anti-theft communication between PCM and BCM)
32 Mass Air Flow Sensor
(No adjustments possible on this component)
Voltage Signal Out of Range
35 Idle Speed Monitor
Idle Speed Error
Sensor Faulty , Wiring or Connector
Note
36 Vacuum Monitor
Vacuum Leak
Vacuum Hoses, Clamps and fittings
Idle Speed Controller Faulty or Sticking
Note
41 Electronic Spark Timing Timing Pulse Problem
(Code sets when Cranking)
PCM Terminal# D10 to DIS Module Terminal A
Wiring Circuit Problem - Open or Ground
NOTE
DIS Module Problem
42 Electronic Spark Timing Bypass Circuit Fault
(Code sets above 1600 RPM)
DIS module, Wiring or Connector
43 Knock Sensor Voltage Signal Outside of Specifications
(Too Low or Too High)
Sensor Faulty, Interference in Circuit
Incorrect Mass Air Flow Sensor frequency output (Low)
Incorrect Engine Coolant Temperature Sensor resistance (High)
Note
44 Oxygen Sensor (Right Bank) Signal Indicates Too Lean
Mechanical Problem
45 Oxygen Sensor (Right Bank) Signal Indicates Too Rich
Mechanical Problem
46 Direct Ignition System No Crankshaft Reference Signal
(Received by PCM when Engine cranks)
DIS Module Problem
Wiring or Connector (DIS Module Terminal D to PCM Terminal #D12)
47 Direct Ignition System / Crankshaft Position Sensor Missing 18X Signal
DIS Module
Wiring or Connector
Note
48 Camshaft Position Sensor No Signal (Received by PCM)
Sensor Fault, Wiring or Connector
Note
49 Camshaft Position Sensor Signal Intermittent (Received by PCM)
Note
51 PCM PROM Error Code
PROM Module
PCM Module
52 System Voltage High (16 V for 109 min.)
Alternator
53 System Voltage High (19.5 V for 2 sec.)
Battery, Alternator, Wiring or Connector
54 Voltage Monitor, Voltage Unstable
55 PCM - Analogue to Digital Signal Converter Error Code
PCM Module
56 Exhaust Oxygen Content (Supercharged Models)
Lean Condition Under Load
Mechanical Problem
57 Fuel Injector Voltage Monitor (Voltage Out of Range)
Main Relay, Battery, Alternator, Wiring or Connector
Note
58 Transmission Fluid Temp Voltage Low
Wiring, Sensor
Note
59 Transmission Fluid Temp Voltage High
Wiring, Sensor or Connector
63 Oxygen Sensor (Left Bank) No Input Signal
Take a look at Oxygen Sensor, Wiring or Connector
64 Oxygen Sensor (Left Bank) Signal Indicates Lean Exhaust Gas
Oxygen Sensor
Engine Mechanical Problem
65 Oxygen Sensor (Left Bank) Signal Indicates Rich Exhaust Gas
Oxygen Sensor
66 3-2 Shift Control Solenoid Circuit Fault
Solenoid, Wiring or Connector
Note
67 Torque Converter Clutch On-Off Solenoid Control Circuit
inspect
69 Torque Converter Clutch Stuck On
Wiring, Mechanical Problem
Note
72 Vehicle Speed Sensor Intermittent While Driving
73 Pressure Control Solenoid Current
75 System Voltage Low
Wiring, Alternator or Connector
76 PCM Fuel Trim Circuit - Short Term Fuel Trim (High)
PCM Module
Mechanical Problem causing Fuel Trim adjust to maximum
Note
78 PCM Fuel Trim Circuit - Long Term Fuel Trim (High)
PCM Module
Note
79 Transmission Temp Too High
Slipping, Overheating, Wiring, Sensor
81 2-3 Shift Control Solenoid Circuit Fault
Check Solenoid, Wiring or Connector
82 1-2 Shift Control Solenoid Circuit Fault
83 Torque Converter Clutch Pulse Width Modulation Circuit
Wiring or Connector
Note
Does NOT illuminate the Power train Check light
85 Transmission Slipping
Difference between Engine RPM and Transmission Output RPM
Note
91 PCM
Quad Driver Module Fault
PCM Module
Note
92 Low Speed Fan No Response from BCM
BCM Module, Wiring or Connector
Note
93 PCM Filter Circuit for Knock Sensor
Signal Noise Enhancement Filter Fault
PCM Module
Note
94 Vehicle Speed Sensor Manual Transmission
(Signal Input Unchanging while decelerating)
95 Transmission
Torque requested is out of Range
96 Air Conditioner Pressure Sensor
Sensor Fail Code
Note
97 Purge Canister fails to Operate
Note
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
vt codes adamandtanya VT - VX Holden Commodore (1997 - 2002) 1 12-04-2007 07:39 PM
codes burnz LS1/2 Development and Modification 0 29-09-2006 04:35 PM
codes for the vr v6 Garth Holden Commodore Info & General Specifications 0 30-04-2004 09:38 PM
codes for vp v8 Garth Holden Commodore Info & General Specifications 0 30-04-2004 09:36 PM
codes for vp v6 Garth Holden Commodore Info & General Specifications 0 30-04-2004 09:34 PM
Mortgages | Credit Cards | Advokat Stockholm | Proxy | Car Loan | Car Reviews
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
