Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 05-05-2004, 08:05 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default vn v6 engine spec's
3.8 liter v6 engine VN
spec’s
cylinder numbers (facing front of engine)
left bank 2-4-6
right bank 1-3-5
Firing order 1-6-5-4-3-2
Flex plate run out maximum
Vn series .02mm
Camshaft
Bearing journal diameter
Vn (upto 11/90) 45.339 to 45.364mm
Vn (from 11/90) 45.334 to 45.369mm
Lobe lift
Vn series (upto 11/90) 6.909mm
Vn (from 11/90), vp, vq, vr
Intake 6.43mm
Exhaust 6.48mm
Acceptable level of camshaft play on all models 0.16 to 0.27mm
Oil pump
Outer bear to housing clearance limit .203to .381mm
Inter gear to outer gear clearance limit .15mm
Gear to end clearance .025 to .089mm
Depth 11.71 to 11.75mm
Diameter 89.10 to 89.20mm
Pressure regulator to bore clearance .038 to .076mm
Torque specifications
Beaming brace
Vn
Clutch housing bolts 15 to.35nm
Torque converter housing bolts 40 to.60nm
Sump bolts 8 to 12nm
Camshaft sprocket bolt
Vn with 3 bolt 30 to 40nm
Vn, 1 bolt 190 to 200nm
Camshaft trust plate screws 12 to 18nm
Crankshaft balancer to crankshaft bolt 270 to 325nm
Cylinder head bolts, in sequence
Step 1 81nm
Step2 turn an additional 90 degrees
Step 3
Vn 81nm
Exhaust manifold to cylinder head bolts/studs 40 to 60nm
Exhaust manifold stud nuts 20 to 27nm
Flywheel/drive plate to crankshaft bolts
Vn (upto 11/90 rope type) 75 TO 90NM
Vn (from 11/90)
Step 1 18-22nm
Step 2 turn an extra 73 degrees
Front cover bolts 20 to 30nm
Inlet manifold to cylinder head bolts 8 to 12nm
Oil filter adapter to timing chain cover bolts 27 to 35nm
Oil pump
Cover screws 8 to 14nm
Pick up tube and screen assembly bolts 8 to 12nm
Rocker arm pivot bolts
Vn to 1989 with pushrod guid plates (series1) 32 to 44nm
Vn 1990 with rocker retainers (series2) 65nm
Timing chain damper retaining bolt 26nm
Valve cover nuts/bolts 7 to 11nm
Use new bolts for vn series flywheel drive plate to crankshaft bolts, discard old one’s. old one’s loose effective thread.
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VLT Diff Spec's overgrown VL Holden Commodore (1986 - 1988) 0 31-12-2007 01:05 PM
VN Engine - Signs of failed engine valves nolim8ts VN - VP Holden Commodore (1988 - 1993) 14 30-04-2007 06:15 PM
ALOT of engine movment... not broken engine mounts commy92 VN - VP Holden Commodore (1988 - 1993) 6 26-04-2006 09:14 AM
Engine stalls and engine light comes on. tysons_2001 VR - VS Holden Commodore (1993 - 1997) 11 01-03-2006 08:01 PM
vl sensor calibration? spec's & procedures basterdvl Electrical Wiring / Questions 0 22-11-2005 04:39 PM
iKobo | Hummer Dealer | Home Insurance | Advertising | atDIR Directory | Car Reviews
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
