Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 05-05-2004, 08:09 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default vs v6 engine specs
3.8 liter v6 engine Vsv6
this spec covers the vs model only
spec’s
cylinder numbers (facing front of engine)
left bank 2-4-6
right bank 1-3-5
Firing order 1-6-5-4-3-2
Flex plate run out maximum
Vs .38mm
Camshaft
Bearing journal diameter
Vs 46.858 to 46.893mm
Lobe lift
Vs
Intake 6.56mm
Exhaust 6.48mm
Acceptable level of camshaft play on all models 0.16 to 0.27mm
Oil pump
Outer bear to housing clearance limit .203to .381mm
Inter gear to outer gear clearance limit .15mm
Gear to end clearance .025 to .089mm
Depth 11.71 to 11.75mm
Diameter 89.10 to 89.20mm
Pressure regulator to bore clearance .038 to .076mm
Torque specifications
Beaming brace
Vs:
Clutch housing bolts 20 to.25nm
Torque converter housing bolts 20 to.25nm
Sump bolts 20 to 25nm
Vs model all fasteners 20 to 25nm
Camshaft sprocket bolt
Vs
Step 1 90 to 110nm
Step 2 turn an additional 90 degrees
Camshaft trust plate screws 12 to 18nm
Crankshaft balancer to crankshaft bolt 270 to 325nm
Cylinder head bolts, in sequence
Step 1 81nm
Step2 turn an additional 90 degrees
Step 3
Vs 90nm
Exhaust manifold to cylinder head bolts/studs 40 to 60nm
Exhaust manifold stud nuts 20 to 27nm
Flywheel/drive plate to crankshaft bolts
Vs
Step 1 18 to 22nm
Step 2 turn a extra 50 degrees
Front cover bolts 20 to 30nm
Inlet manifold to cylinder head bolts 8 to 12nm
Inlet manifold to plenum bolts only 10 to 14nm
Sump bolts 8 to 12nm
Oil filter adapter to timing chain cover bolts 27 to 35nm
Oil pump
Cover screws 8 to 14nm
Pick up tube and screen assembly bolts 8 to 12nm
Rocker arm pivot bolts
Vs
Step 1 15nm
Step 2 turn a extra 90 degrees
Timing chain damper retaining bolt 26nm
Valve cover nuts/bolts 7 to 11nm
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
HELP>>>V6 engine torque specs. underthepump VN - VP Holden Commodore (1988 - 1993) 2 03-05-2007 08:53 PM
Engine oil specs NetJunkie General 1 28-05-2006 02:27 PM
vr v6 engine specs Garth Holden Commodore Info & General Specifications 0 05-05-2004 08:07 PM
vp v6 engine specs Garth Holden Commodore Info & General Specifications 0 05-05-2004 08:07 PM
v8 engine specs Garth Holden Commodore Info & General Specifications 0 05-05-2004 07:59 PM
Loans | Personal Loans | Loans | Spanish Property | Xbox Mod Chips | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
