Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 12-05-2004, 08:01 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default How to check Map sensor
1. After locating the MAP sensor (using a service manual if necessary), disconnect its wiring harness
2. To test the MAP sensor, run jumper wires between its terminals and wiring harness per the service manual's instructions. Turn the ignition to the ON position and take a voltage reading. Spec for this MAP is about 4.5-5.0 volts.
3. With the engine running and warmed up, take another voltage reading. It should differ from the non-running number and fluctuate when the engine is revved. If not, verify that the vacuum line isn't damaged or blocked.
4. the vacuum line checks out, the sensor is likely faulty. Replace the bad MAP with a new one by connecting the vacuum hose and wiring harness, then securing the sensor to its factory location.
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6? mulligan-can VN - VP Holden Commodore (1988 - 1993) 3 07-05-2007 08:08 AM
VR o2 sensor check how? iroczinoz VR - VS Holden Commodore (1993 - 1997) 5 23-10-2006 10:09 AM
Check Engine (O2 Sensor) L&T POCLAIN VY Holden Commodore (2002 - 2004) 3 14-07-2006 07:25 PM
VN Check this out wes_v8 VN - VP Holden Commodore (1988 - 1993) 20 12-07-2006 01:44 PM
how come thermo fan comes on when i do a sensor code check vl rb30 VN - VP Holden Commodore (1988 - 1993) 4 23-12-2005 09:44 PM
Loans | Myspace Layout Stealer | Personal Loans | Loans | GameCheatsCodes | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
