Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 12-05-2004, 08:03 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default Good little 'HOW TO" on fuses
General information on fuses
All electrical circuits are protected by a combination of fuses and circuit breakers. Some vehicles also use fusible links. There are two fuse blocks on the Commodore, a main and engine compartment block.
The main block is located behind the drop down cover directly below your steering wheel, this cover can be dropped by turning each of the plastic inserts 45 degrees with a 10c coin or similar. The engine compartment block is obviously located in the engine compartment and can be found on the driver's side near the battery. This block contains most of the relays as well as the fusible links.
Each fuse is made to protect a specific circuit, and the various circuits are listed on the fuse panel itself. On more than one occasion I have witnessed someone in a VN stranded at a service station. Only to be saved by a mechanic who walks out and replaces the 10A ignition fuse. The humble fuse is something that should never be overlooked.
If an electrical component fails you should always check the fuse first, under normal operating conditions a blown fuse is the most common reason for component failure. How do I know if a fuse is faulty? I hear you ask. Spotting a blown fuse is really quite easy. With the suspect fuse in your hand, examine the clear plastic body; if the wire inside has a small black mark, gap or break you have a blown fuse. However, sometimes a faulty fuse is not as easily spotted and you may need to do a continuity check.
To check for continuity simply place a multi meter between the 2 feet of the fuse and select the ohms scale. An operational fuse should have a reading of 0 ohms, indicating no resistance. Fuses with resistance must be renewed.
When renewing a fuse it is good practice to replace it with one of identical rating. For example, if a 20Amp fuse is blown you simply replace it with a 20Amp fuse, nothing more or less. Fitting a fuse with a rating higher or lower than factory specification is not recommended, as each circuit needs a certain amount of protection. If you go lower the fuse will blow too easily, this is referred to as “nuisance blowing”. On the other hand if you go higher it just won't blow, providing no protection at all.
Please Note- If a fuse is renewed correctly and immediately fails you have an electrical fault. Do not renew the fuse again until the cause of the problem has been rectified. A short circuit in the wiring caused by broken or deteriorated wire is the most common problem.
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wanted:good comeback line for "Do you know what your doing?" gibbo The Pub 53 09-05-2007 10:06 PM
Can you find the "C" ??? (Good exercise for the eyes!) Be ready to go blind. Juzza Jokes/Humour 29 08-12-2006 01:26 AM
good 18" tyres Troy711 General 27 10-06-2006 10:38 PM
do 16" rims look good on vn's?? Fully VN - VP Holden Commodore (1988 - 1993) 21 14-09-2005 04:04 PM
Rewards for "good drivers"... Snowfox The Pub 10 03-04-2005 12:12 PM
Problem Mortgage | Chicago Dedicated Servers | Loan | Car Accident Lawyer Los Angeles | Personals | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
