Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 12-05-2004, 08:05 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default Fluid and lubs
Capacities
Engine oil (with filter change)
V6 4.1 ltr
V8 5.1 ltr
Fuel tank *
Sedan 63 ltr
Wagon 68 ltr
Cooling system
VN V6 10 ltr
VP VR, VS and all V8 models 12 ltr
Manual transmission 2 ltr
Auto transmission
Fluid and filter renewal V6=4.8 ltr, V8=5.0 ltr
Total capacity (including torque converter
700 r4 and 4l60 models 11 ltr
4l60-e model V6=7.9 ltr, V8=10.6 ltr
Rear axle 1.7 ltr
Power steering system (in resivour) .65ltr
Brake system (in filler bottle) .67 ltr
Radiator cap pressure rating
V6 135kPa
V8 100kPa
Radiator surge tank cap rating 120 to 150 kPa
Brake pad wear limit 3mm
Clutch pedal height (cable operated systems) 166 to 170mm
Ignition system
Firing order
V6 1-6-5-4-3-2
V8 1-2-7-8-4-5-6-3
Spark plug type
V6 AC R44LTS6
V8 AC R42LTS
Spark plug gap
V6 1.4 to 1.5mm
V8
Vn, Vp .95 to 1.05mm
Vr Vs .8 to .9mm
Ignition timing
V6 Non adujustable
V8 10-degrees btdc in diag mode
Idle speed in neutral 600 to 800 rpm (non adjustable)
Torque spec’s
Spark plugs
V6 20 to 25nm
V8 20 nm
Sump bolt 30 to 60nm
Auto transmission pan bolts 11nm
Wheel lug nuts
Aluminium wheels 125nm
Steel wheel 108nm
Engine block coolant drain plugs 35nm
Throttle body bolts
V6 10 to 20nm
V8 15 to 18nm
Please note, all fluid capacities are a approximate only, add to bring to proper level as needed. Also statesman, caprice, utes, and extended range tanks capacity’s will vary
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Last edited by shaggerz; 22-01-2007 at 12:58 PM. Reason: Added V8 Specs for Auto Transmission - Courtesy of BlackVXGTS
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Which transmission fluid jonathanvb VN - VP Holden Commodore (1988 - 1993) 2 13-02-2007 06:50 PM
Brake Fluid and Auto Trans Fluid. Melchior3 General 4 20-02-2006 11:49 AM
Transmission Fluid Indy_387 VN - VP Holden Commodore (1988 - 1993) 2 04-06-2005 12:03 PM
VP fluid leak abzy VN - VP Holden Commodore (1988 - 1993) 3 13-01-2005 06:12 PM
Transmission Fluid MavVP VN - VP Holden Commodore (1988 - 1993) 1 24-08-2004 09:07 PM
MPAA | Electricity Suppliers | Charity | Credit Card Debt Consolidation | Hummer Dealership | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
