Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Closed Thread
LinkBack Thread Tools Display Modes
  #1
Old 19-08-2004, 08:29 PM
the Noob
Ride: vns2
Trade Rating: (0)
Garth Off the chartsGarth Off the chartsGarth Off the chartsGarth Off the charts
Default oxygen sensor
this is just a little story on the oxygen sensor, that way you can understand it a bit better, and mabey stop posting all the time about fuel related issues
The oxygen sensor's job is a easy task, all it has to do is measure the amount of oxygen content in the exhaust stream. The way a oxygen sensor works is it will measure the amount of oxygen content in the exhaust by causing a reaction on the oxygen sensor itself. i guess you could call this very similar to the way a thermistate operates for heat.
when the oxygen sensor react's it creates a output voltage ranging from 0.1v upto 0.9v (.1v is high o2, lean fuel/air ratio, where .9 is low oxygen rich fuel/air ratio) The 02 sensor sends this output voltage directly to the ecu/pcm (depending on model of car), this will cause the pcm/ecu to react and change the mixture of fuel/air. the way this happens is the pcm/ecu will mix the ratio by controling the length of time a injector will stay open for, (squirt fuel). The ideal fuel ratio mixture for the v6 is 14.7 parts air to 1 part fuel, this is for ideal normal driving conditions, i.e. not floging the guts out of your commie, it is this mixture your ecu/pcm will attempt to maintain while crusing at a speed above 53kmph
if your oxygen sensor is failing, the ecu/pcm will receive a constant output voltage from the 02 sensor, i.e. .6v so your pcm will alway's keep your fuel mixture at a ratio of 14.7 parts air to 5 parts fuel, as a result. yoru car will run rich, lose performance and chew fuel like there is no 2morrow
__________________
Just because i can
Local electrician
__________________
attn parents
all unatended children will be given a shot of caffine, promised a puppy and promptly returned
have a nice day
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
oxygen sensor SSbeast VR - VS Holden Commodore (1993 - 1997) 55 26-04-2007 12:36 PM
Oxygen sensor da_almighty_fat_man VR - VS Holden Commodore (1993 - 1997) 11 09-12-2006 11:32 PM
Oxygen sensor wogski VN - VP Holden Commodore (1988 - 1993) 12 31-08-2006 09:23 PM
oxygen sensor ab56452001 VN - VP Holden Commodore (1988 - 1993) 44 10-07-2006 03:33 PM
oxygen sensor merlinp VR - VS Holden Commodore (1993 - 1997) 1 02-09-2005 05:46 PM
Online Loans | Shares | Loans | Köp och Sälj | Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
