Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Holden Commodore Info & General Specifications
Reply
LinkBack Thread Tools Display Modes
  #1
Old 17-03-2005, 10:00 PM
Ride: N/A
maccaorgordon Executive
Angry Vn Radiator bottle....
Hi
l'm after a radiator bottle cap from a vn series 1 or 2 ? it has an outlet coming from the actual cap and a hose that runs from that bottle to an overflow bottle on the passenger side .l've been given a cap from a vp and was told to get rid of the overflow bottle .Doesn't this mean that that pressure is trapped in the cooling system and the car would more than likely overheat ?If l could get a cracked one l'd be able to repair it ..
[l think ?]Hope someone steers me in the right direction
Regards Mac...
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 18-03-2005, 04:13 PM
Ride: N/A
Trade Rating: (0)
jules Calais
the vn cooling system is a pressurised system.
the bottle cap on my series 1 v6 vn has no hose on it and no overflow bottle. the reservoir is itself an overflow bottle, which accepts fluid bled into it from the cooling circuit via a pressure regulator.
i can't remember if there is an overflow pipe on it or not, but no bottle i'm pretty sure.
  #3
Old 19-03-2005, 08:25 AM
Ride: N/A
Thumbs down jules
That is fine for your setup but my original was with the two bottle system as the radiator itslf has no radiator cap l'm after the ORIGANAL cap with the outlet from it
Macca
  #4
Old 01-04-2005, 12:09 AM
Ride: VN berlina
Trade Rating: (0)
movn Executive
ther is none..... V6 series 1 VN's have no radiator cap ur right about that, they ONLY have a surge tank next 2 washer bottle, no over flow bottle. The cap for the surge tank has a relief valve in it and if excess fluid needs 2 escape then it will escape through that valve, what ur describing is NOT original. If ur car has NO radiator cap then remove the overflow bottle it AINT sposed 2 be there. no commodores will have a surge tank AND an overflow unless sum ********s fitted it.... Im a mechanic and i own a VN and i cant figure out how that would actually work having both bottles, i recomend removing the over flow, looking at ur car from front, radiator has TOP and BOTTOM hoses and ONE small hose coming from top right hand side of radiator that hose SHOULD go to left front side of surge tank, off surge tank will be another small hose and 1 medium hose, small hose goes to manifold, medium hose goes to T piece...... MOVN
  #5
Old 07-04-2005, 09:20 PM
Ride: N/A
Thumbs down VN surge bottle
vn v6 models built from 18/4/90 to 1/11/90 were fitted with an additional overflow bottle and surge tank cap part number 92040745 they stopped making the caps about july 1993 it says in the report l got that in the event the original cap has been lost or damaged there is no alternative other than to fit the present cap part number 90409256 which renders the overflow bottle inoperative ,GMH. said that it leaves about 21 lb pressure back into the cooling system and l'm having troubles because of this that's why l was after the original cap but it looks as though l have to fit a new radiator with the radiator cap.at least this way the extra pressure will be able to escape when the temperature rises.][IMG]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Mechanics in a bottle Northern_Union General 27 20-01-2008 11:05 PM
radiator overflow bottle. lord_davros VN - VP Holden Commodore (1988 - 1993) 5 02-11-2007 11:44 AM
overflow bottle 12000 VN - VP Holden Commodore (1988 - 1993) 1 17-01-2007 11:14 PM
Changing Radiator Overflow Bottle to a Washer bottle nick88 VR - VS Holden Commodore (1993 - 1997) 3 11-10-2006 01:12 PM
Radiator Overflow Bottle/Washer Bot groucho VL Holden Commodore (1986 - 1988) 3 28-06-2006 10:42 PM
Remortgages | Advertising | Loans | Cell Phones | Cash ISA | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
