Gav I think the total height of the motors will be the same, the VS engine might just look taller but the actual block is shorter than the VN motor because it was designed to fit in a front wheel drive, it has shorter pistons, if the plenum is taller it might work out about the same, messure it before you go chopping and welding. You should be able to run a VS manual or VR manual computer in it, or a VN computer even
