It's really not too difficult fixing your own hard drive, if the problem is a head crash, or the infamous Seagate "stiction" problem, if you know what to do. You will need #4/0 steel wool, paint thinners, WD-40, a few hand tools, and about 45 minutes.
First, you need a clean room, so make sure the garage door is closed before you begin. Move those old lawnmower parts off the bench. Disassemble the sealed unit and carefully wash all parts with paint thinners. Bend the read/write heads out of the way, and then disassemble the platter stack.
VERY CAREFULLY buff the platter surfaces with the #4/0 steel wool. This will remove any existing data, level out any surface defects, and help to redistribute the magnetic media and fill in those pesky "bad sectors" that most drives have.
Reassemble the platter stack, and using a .015" feeler gauge, bend the read/write heads back to the platter surface, using the feeler gauge to set the gap. This is slightly higher gap than the factory uses, but it reduces the chance of head collisions with any flotsam you neglected to remove.
Give the heads and platters a good shot of WD-40 and reassemble the unit. If your drive has a filter, replace it with a clean section of gauze pad.
All that's left is to low level and DOS format the drive, and you're back in business. I haven't tried this myself, but my friend's wife's sister-in-law's husband knows a technician that does it all the time....
friends wifes sister in law's husbands mothers brothers nieces parol officer does it all the time HAHAHAHOriginally Posted by rattattack1313
also to prevent your clothes from discharging static on anything you must do this naked
[does anyone else ready megatokyo by chance?]
attn Über geeks, i play Second life. Patrio Graysmark.
I'm disturbed!
If you don't really want to do this naked grab on to a metal object... Should discharge you pretty good. If you want to fry everything, rub your feet from one side of a room with carpet to the other, while wearing socks... should built you up a good 40,000 volts of static electricity.
I don't use windscreen wipers, i just use the superior handling of the STI to dodge the rain drops.
yano if ur naked and you do this dont make the same mistake i did by touching ur balls witht he thinners... and then smoking irritation and then up when my pubes... lol
