Bizmark
I'm due for a lead change soon and have seen some eagle leads (which are said to be high performance) on ebay for a decent price. Do the eagle leads have any benefit over the genuine leads?
i have always used 9mm (grey) eagle leads on my vrii, with bosch super 4 plugs.. They shite all over the gm leads...
Heaps more power & smoother acceleration.. As the resistance changes from the coil packs to plugs...
Tested the eagle leads on my standard vn commodore & it boosted power by about 15-20 bhp with the super 4 plugs... It runs like new..
forget eagle and get some Bosch leads. i've used eagle for years and i've gone back to Bosch. i use the ones listed for LPG use.
15-20bhp on plugs and leads alone ............:blah blah: i call BS<<<<<???:banstick:
Im with the first guy, Ive got the gray 9mm Eagle leads and they have done over 40k and still run mint, (test showed near new ratings) Using NGK plugs and VY coil pack.
It HAS Been Proven, To Actually Get 15-20Kw, With Pro 9mm Pro Leads, Super 4 Plugs & High Flow Air Filter... I Think Your Misses Called BS When She Got Stuck With You...:boxing:
I'm A Performance Patent Designer Fella... What Do You Do..??? That's Why, All The Turbo Charged Cars In My Area HAVE Been Put To Shame By A 20 Year Old Series 1 VN... :rofl2:
I've Driven All The Way Up Past LISMORE From SYDNEY & Back Four Times, To See My Ex & Hit Speeds Of Over 250kmph.. Three Months Later, Gave The Plugs A Clean & Stuck The Leads & Super 4's On The VN... Still Running Strong...
