Results 1 to 7 of 7
Thread: Important tools for the garage.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Default Important tools for the garage.
    DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your drink across the room, splattering it against that freshly-stained heirloom piece you were drying.
    WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar callouses from fingers in about the time it takes you to say, 'Yeouw....'
    ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age, or for perforating something behind and beyond the original intended target object.
    SKIL SAW: A portable cutting tool used to make studs too short.
    PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. Caution: Avoid using for manicures.
    HACKSAW: One of a family of cutting tools built for frustration enhancement. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 45 minutes.
    TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
    TWEEZERS: A tool for removing wood splinters and wire wheel wires.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
    RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
    TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, 'the sunshine vitamin,' which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40- watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. The accessory socket within the base, has been permanently rendered useless, unless requiring a source of 117vac power to shock the mechanic
    senseless.
    PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids, opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
    AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact gun that grips rusty bolts which were last over tightened 40 years ago by someone at VW, and instantly rounds
    off their heads. Also used to quickly snap off lug nuts.
    PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to make hoses too short.
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
    MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. It is also useful for removing large chunks of human flesh from the user's hands.
    DAMMIT TOOL: (I have lot's of these) Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need after a really big hammer
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    vn/vp Speedway Street Sedan
    Sep 2005
    VX-II Lumina Sedan
    Nov 2003
    Bluff, Queensland
    RING SPANNER: so called because of the distinctive ringing noise it makes when it ricochets off the workshop concrete floor when you angrily throw it after it has slipped, skinning your knuckles on the nearest sharp metal edge to what you were trying to loosen.
    VICE GRIPS: an efficient mechanism designed for trapping the flesh of the palm of your hand in between the grips, after firmly clipping it onto a reluctant fitting. At this point, it is also garanteed to be far too tight to undo with your one remaining hand as you stagger around the workshop with one of those "it hurts too much to even scream" looks on your face...
    ALLEN KEYS: L-shaped hexagonal shaft tools designed by a sadist named "allen", which you can be garanteed of going through an entire drawer of before finding one that sorta kinda fits what you want to loosen...and then it will round off before it loosens the screw.
    TORQUE WRENCH: A piece of equipment which, even when brand new out of the box, is designed to create a haunting feeling in the back of your mind that maybe it wasn't calibrated properly or doesn't work correctly anymore (after all, how would you know?) and that your carefully assembled big end on your brand new motor is about to let go in a rattling heap of scrap metal.
    PIN PUNCH: designed to put a small indentation in a metal surface which will locate the drill bit almost, but not quite, in the exact spot you want it to go.
    WOOD CHISEL: Sharp, flat tipped tool, used for removing paint can lids, scraping off gaskets, cutting fence wire on an old steel block, scraping paint off metal surfaces before welding, chipping off slag after welding, levering reluctant fittings into place...and can possibly also be used for chiseling slots in pieces of wood...but who uses them for that?
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    FG XR6T Ute manual
    May 2007
    Brissy
    I laughed for 20 minutes after i read those. Especially the DAMMIT tool and the trouble light
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    HA-HA-HA!!!
    24 carat SOLID GOLD!!
    Loved the drill press and ring spanner in particular...
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. what is more important to you?!
    By jet_pilot in forum General
    Last Post: 29-01-2008, 04:02 AM
  2. tools
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2007, 10:54 PM
  3. more important (Go or Show)
    By flyen in forum Just Commodores Polls
    Last Post: 11-10-2006, 01:34 AM
  4. Tools
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 09:47 PM
