View Poll Results: EFI or Carbed
Voters
63. You may not vote on this poll
  • EFI
    47 74.60%
  • Carbed
    16 25.40%
Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: EFI or Carbed 5L
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default EFI or Carbed 5L
    hey.
    just wondering what do you prefer, EFI or Carbed 5L and why, what are the pros and cons of them..
    thanks
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    carby.. you can go wild with the cam and not worry about low Hg.
    plus it's more of a hands on setup without the softwear side of things, sortof old school more fun in my book.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    I'd go for the carbed, easier to work on, sounds better, cheaper to service.
    But the EFI does give better power and efficiency.
    VP Executive R-spec
    Jan 2005
    EFI, better motor, less fuel more average power, for most people injected motors sound better too
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by v8freak55 View Post
    Which bit of carbed is cheaper to service and (for that matter) easier to work on? Pollution crap started to strangle most carby cars in the late 70's and by the early 80's it was beyond a joke. The only thing easier to work on with a carb holden v8 is the dizzy but then again on most efi motors it's rarely touched. Compare that to trying to set the mixtures etc etc on a carb that need to be constantly adjusted yet most people have nfi how.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VP Executive R-spec
    Jan 2005
    Not only, I bet there's more people know how to self tune a efi car properly these days than ever knew how to tune a carby properly
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    yer, i dont want to f**k around with the mixture. but ill still wait for more decisions and decide then.
    VK Commodore & VY SS Ute
    Nov 2009
    with EFI if you want power its more of a hassle if you get done by EPA because if you want good power you need TTB manifold or blown application and computer, all of which would have to be removed for EPA inspection (if you ever get done for it).
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    pfft to all of you. mixtures are a piece of piss. two screws on most cars and a good vac guage. i sometimes just mess with them for a luagh and see what happens when i richen the crap outta it (psst, it doesnt do anything except make your car flat spot)
    carb is much better. better top end power, better sound, the worst fuel economy ever! less down low power and you have to change jets - mess with timing- adjust springs and opening rates on hot/cold days. but personally i think they are a lot more fun. its hands on old skool style.
    having said all that i work on efi cars all day everyday so i guess its also the fact that carb is something different.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i've had a few carbied 5.0's and i'm on my second EFI 5.0. they were all good to me
    i guess if u wanted an everyday driver that u were not going to go crazy on EFI would be the go, good economy, reliability etc.
    if u wanted a cranky weekend toy a carby would definately be the cheaper option, for example:-
    induction and tune up costs
    carby- $1000 should get u a decent carb and manifold if u shop wisely, find a mate who is handy with carbs and give him a carton to tune it
    EFI- decent manifold will be worth heaps, walkinshaw- VN group A = $5000+ easy. COME racing one will see no change from $2500, then getting it tuned will be (possibly way) more than $500 at the dyno joint down the road, if u go with an aftermarket ECU theres 1-2 grand on top as well
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by dirt drifter View Post
    EFI dual plane manifold is less than $1000 + TB. Tune is way less than $500 if you can't do it yourself. Several on this forum do the tunes for 2/10 fa!
    Reaper
    Reapers Black VP SS
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by [BOSSVK] View Post
    Hold on....So we are talking Commodores here, all of which are illegal with either a Holley or a quaddy with the emissions equipment removed. So, if you get done for EPA which would be less hassle? An EFI engine which only requires a charcoal canister and a Cat convertor or a Carby which requires all the emissions equipment to be operative? Why would a twin throttle manifold have to be removed? Why would the ECU have to be removed? Bearing in mind most people just have the factory Delco retuned, not fit an aftermarket ECU....
    Most people go Holley, no Commodore will pass EPA with a Holley (infact anything post 76 won't pass with a Holley).
    EFI is much easier to get past EPA.
    For me, it's EFI hands down. Although i would have a carby on a weekend only cars, but i would certainly prefer EFI.
    Jun 2005
    tim, whats the go with EPA and aftermarket manifolds such as a torque power? i thought it would require a standard manifold to pass
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Jun 2005
    I couldn't really see any reason why it wouldn't pass with a TP manifold and 4 barrel T/B. Providing the charcoal canister is still operative/connected up i wouldn't imagine there would be any dramas as it's still fuel injected and the emissions equipment is still there. The drama would be the cam that goes with it, however, if you could get the emissions somewhere near stock, that should be ok too. As far as i can see, aslong as they stick a sniffer up the bum and it's somwhere near what it should be it should be fine.
    I guess it could be a bit of a grey area though...
  15. #15
    VH SS
    May 2009
    Toowoomba, Qld
    I swapped carb for EFI in my car and would never go back
    I reckon EFI is simpler than carbs. You can see the sensor readings, so you have a visual on what the engine is doing. Carb engines involve a lot more guesswork, unless of course you have your own expensive engine analyser. Often it takes a professional tuner to set up a carb correctly on a particular engine anyway. They are often extremely complex devices.
    Also EFI, you do tend to spend more time/money getting the tune setup - but once it's setup.... they self adjust with engine wear & different climatic conditions. You don't need to touch it again, unless you carry out significant engine changes. Carbs constantly need fiddling with to keep them happy.
    I love the fact that you can hook up to an EFI engine with a laptop and tweak the tune with the press of a key (providing you have a real time calibration ECU). And you can't beat the driveability. Cold start on a freezing cold morning - no winding over, pumping the throttle and then sitting in the driveway for the next few minutes warming up. Start up an EFI engine on a cold morning and drive away. EFI tames big cam engines. A big cam carb engine tends to be a bit of a pig to drive around town, whereas the equivalent EFI engine can be tuned to have very pleasant street manners.
    Add to that better fuel economy, electronic ignition timing & I prefer the sound of an EFI 5L over carb! They always sound so much bigger and throatier, especially when you give it a bootful
    Bang for buck (at least when it comes to a Holden 5L), carb is probably more cost effective up to a certain point as the EFI Holden V8 aftermarket intake manifolds are extremely overpriced when compared to carb manifolds, then there's the extra cost of upgraded injectors, expensive tunes etc
  16. #16
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by Darren_L View Post
    so i take it your leaning towards EFI cause i am, from what you have said, sure its a bit more expensive but its worth it for cold mornings and tunability??
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by vkcommo View Post
    there is such a thing as a choke and a thermostat on carby'd engines. my engine is simple to start. jump in, prime the fuel pump for a second (leaky carb, gotta fill the bowls, shhh) one squirt on the throttle and VROOM. Mallory does the rest.
    and like it or not, efi or carb'd holden will still snap rings if you drive a cold engine, its one of those lame 5ltr things. go easy on cold holdens.
    if i were you i would go EFI too. its cheaper and better for everyday use.
    P.s. efi still has EGR, which is the only real restirction on the engine that EPA are looking for, other than induction/exhaust.
  18. #18
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    I prefer EFI but with the carbied look, thats why i run a 4bbl TB unit on my 308 with LINK ecu (which needs a full re-wire ). no EPA worries here in NZ plan to rebuild with a TP manifold (instead of the edelbrock performer DP mani) and decent cam one day as my cam is stuffed
    Body by Holden, Soul by Brock
    the Legend will live forever
  19. #19
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    what about EFI with a high rise manifold and one of those T/B's that look like carbys, i'd like that.. lol
  20. #20
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by ari666 View Post
    whats that?
  21. #21
    Reaper's Avatar
    Aug 2004
    From my VP thread in my sig....
    That is a Torquepower dual plane low rise manifold and 4 bbl throttle body. Your manifold selection really depends on what you want from your car and the engine you run. Unless you have a big stroker or something wild the low rise dual plane would probably be the go for most street cars that need a little more than standard bananas can give. Is mistaken for a carb by some too.
    Reaper
    Reapers Black VP SS
  22. #22
    Jun 2005
    Tell me what EFI 5 litre has an EGR on it? Late V6's (VT onwards) have an EGR valve but the EFI 5 Litre never had an EGR....
  23. #23
    ari666's Avatar
    1966 impala
    Mar 2009
    how the hell did holen manage to get a 5 litre V8 to pass 37/00 with no egr???? i smell dodgie. you sure there is no exhaust crossover at all on those heads?
  24. #24
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    @ reaper, thats what i want, the look of carb but without the hassle of it, so im thinking of high rise so the throttle body and filter are sticking out, like on RACE5L's VH.
  25. #25
    Reaper's Avatar
    Aug 2004
    At the expense of engine performance??? Clazy!
    Reaper
    Reapers Black VP SS
  1. carbed 308 to a efi vn hsv
    By vr5speed in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-11-2009, 08:36 AM
  2. backyard tuning black carbed 202
    By VKCOMMO in forum Tuning
    Last Post: 30-10-2009, 05:34 PM
  3. carbed to fuel injection
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2009, 06:08 PM
  4. Vk EFi extractors on a Carbed?
    By Dogmeat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2005, 02:57 PM
