Nulon
Penrite
Castrol
Shell Helix
Valvoline
Repco/Bursons brand
Other
What oil have you guys used and had the best result with, just 20w-50 i have wrote all i can think of any other oils i have not mentioned write below.
royal purple
My race engine builder swears by castrol edge 25w 50w,he builds and refreshes engines all the time and finds the condition of bearings very pleasing,he said if I ever put mobil 1 in any of his engines that I wasn't to ring him anymore!!!!!!
Penrite
and then castrol and nulon are about equal imo,
shell is rubbish and so is valvoline
Any oil with an API rating of SN will be better then older an oil such as SL and SM. But then some SN oils are better then others, it all depends on what additives the individual manufacturers put in the oil, so some blends may be better for some engines then others, depending on there needs. Personally i like Fuchs oil but its not readily available so i use Castrol more commonly.
