Results 1 to 4 of 4
Thread: help me turn my shuttle into NAS
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default help me turn my shuttle into NAS
    a while ago i built up a shuttle using alu. tube from bunnings and a hdd rack from chenbro. it was originally meant to be esata using a sata port multiplexer card, but it never seemed to work, so i just use 4x sata > usb cables and a hub in it.
    pics:
    just won an auction for a PC-on-a-card that i thought i could put in there to make the case NAS instead of USB.
    link to pdf of card specs
    it's got a usb header (only 1.0) , and a 10/100 eth, and supports socket 370 up to 500mhz.
    is it worth using for this? i was originally going to use it for a carputer, but now i'm going another way.
    just worried the usb 1.0 will make it shite for media (the shuttle is TV/music/movies) but with no on board sata i don't think there's a way round that
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    usb 1.0 will be sooooo sloooowwwww.....
    Its gotta move data faster than that or you'll start to see really bad lag, spesh on big moves of data.
    aZk.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah that pretty much confirms suspicions. wonder what else i could do with this board.
    VT Acclaim S2
    Apr 2009
    you could always put it in your current pc, as long as you've got enough hdd bays and sata ports. either that, or you could sell them, and just get a NAS or portable hdd from the money you make.
  1. Key won't turn?
    By tristan2355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2011, 08:08 PM
  2. Space Shuttle Launch STS-120
    By RufusŪ in forum The Pub
    Last Post: 07-12-2007, 08:02 AM
  3. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  4. shuttle valve
    By statement in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2005, 03:46 PM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
