Results 1 to 9 of 9
Thread: azureus problems. torrenting nightmare
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default azureus problems. torrenting nightmare
    been having a few problems with azureus (vuze) lately
    start a torrent, leave the room
    come back later, torrent has made some progress but looks to have stopped.
    • pc won't internet/chat.
    • kill vuze - vuze still shows in task manager/procexplorer, won't die from either.
      try to 'repair' connection, repair window doesn't get past the renewing ip bit.
      restart modem/router, no internets/torrenting still.
    i recently install the rss scanner plugin for azureus/vuze but had no real joy with it so i uninstalled it.
    running vuze on my netbook too and no dramas, but the install on that is 4.2.0.0 (desktop runs 4.2.0.2) and also runs a slightly older java.
    really don't wanna switch to uTorrent or another client. all help appreciated/repped
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    what windows are you running? xp or vista??
    There are different options that you can try but I will need to know which one you are running first.
    XP
    Download Winsock XP Fix and run it.
    Restart the computer and try programs again.
    VISTA
    Hold 'Windows key' and press 'R'. This will bring up the windows run box.
    Type CMD in the run box and press enter.
    this will open command prompt.
    In the command prompt window type: netsh winsock reset
    after that has finished, type EXIT and restart the computer.
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I'm havin same kind of dramas but i believe it to be my isp dodo slowing the ports that vuze uses on purpose as to stop "illegal downloads". I am still to find a way around this if its even possible.
    I start vuze, it starts ok then gets seeds, then it will slow to a crawl and barely download if it doesn't completely stop. Sometimes need to reboot modem to play warcraft or surf afterwards. I'm no expert by any means lol, but i researched all i could and i believe im using the correct ports, and that my isp is port shaping my connection. (according to what i have read from other dodo users). I was with a diff isp last year and never had these torrent problems.
    ========My Statesman 20's Mafless and 3.9's========
    Jun 2005
    have noticed a few torrents of mine being a bit slow. i dont use them often, but the latest have been a bit slow, when they really should not have been. i mean brand new movies with 1000s of seeds
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    i gave up on vuze and changed to utorrent much happier less ram usage and speeds seem to be as good if not better got most of the features vuze has
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by ucwepn View Post
    try switching ports? there's a whole slab of ports you can use, they can't block them all, they're not unique to vuze
    VN S1
    Jan 2008
    Yep i had the same issues with dodo i changed ports then redid the port number in the modem and run peerguardian constantly and all is perfect again.
    ucwepn's Avatar
    WH statesman 5.7
    May 2005
    ya i tried a really high range port and its improved but its still not 100% maybe dodo are just slow lol, am in peak time now so we'll see how it goes overnight might be better
  1. Vl Nightmare! :(
    By Brenno85au in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-04-2010, 10:26 AM
  2. god damn thermostat nightmare
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-07-2006, 09:05 PM
  3. Nightmare- 2 flat tyres!
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2006, 11:20 AM
  4. listen to this nightmare scenario
    By just george in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 06:22 PM
  5. Nightmare of Bliss
    By stretch in forum Jokes/Humour
    Last Post: 01-08-2004, 02:22 PM
