Results 1 to 4 of 4
Thread: Playing MP3s from computer on Surround sound with Bluetooth?
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default Playing MP3s from computer on Surround sound with Bluetooth?
    Is it possible to play my music files from my PC though my home theater system with Bluetooth?
    Both have BT on them, I can play MP3s off my phone through BT on the surround sound and want to do the same with the PC.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    blue tooth has a fairly limited range, how close is the pc to the home theater receiver
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Close enough to be able to pick it up. When I search for devices on the PC I can find the home theater system.
    Subaru Liberty
    Feb 2007
    Yes. Set the HT system bluetooth to visible, and then search for it on the PC. Once found, pop in the 4 digit password (usually 0000 or 1234) and let it connect.
    Once all done, set the HT system to wireless stereo, then you should be able to play the mp3s on your computer and have the sound come out of the HT system.
    Just a quick note though, your mp3 files will be in stereo, so you will not get full 5.1 surround sound. Most likely sound will only come out of the left, the right and the subwoofer.
    <<<< The information went data way! >>>>
  1. Holden Bluetooth Car Kit
    By mav® in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-07-2009, 02:15 PM
  2. VZ bluetooth compatibility
    By SgtBundy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-04-2009, 01:00 AM
  3. Replies: 7
    Last Post: 27-11-2008, 09:31 PM
  4. On the Bluetooth
    By for me in forum Electrical Wiring / Questions
    Last Post: 04-11-2008, 11:56 AM
  5. Holden Bluetooth Kit
    By minux in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-10-2007, 03:49 PM
