If it were in a sealed enclosure such as a cupboard, I'd want a large (at least 10cm diameter) mesh opening at the front/bottom of the cupboard, and an even larger one (12-15cm) as high as possible at the back. Computers generally draw air from the front/bottom/sometimes the sides, and exhaust air at the top/rear.
If your case has the cpu air intake (look for a circular vent on the left side of the case, looking from the front), make sure you give yourself about an inch of clearance on that side.
LinkBack URL
About LinkBacks
