Results 1 to 9 of 9
Thread: Laptop keeps turning off!!!
    VS UTE
    Jan 2008
    Default Laptop keeps turning off!!!
    Hey,
    i have a toshiba satellite pro A210 running windows XP,
    First off it keeps turning off, if i try to start it back up it turns on for a second the back off, if i leave it for like 5 minutes it might make it to the windows loading screen, if i leave it for an hour i can use it for 15 etc...
    so the longer i leave it off, the longer i can use it before it automatically switches off.. its switchng off like it has a flat battery... (But it dosent)
    Also it wont boot without the battery (even with external power)
    And wont boot without external power (With battery)
    Its Making a ticking noise (jjust under 1second gap between ticks)
    and its only a little louder than a watch..
    also every second tick my Hdd light on my laptop flashes, like its in time with it..
    All these problems started at the same time so im guessing there related..
    Whats wrong with my laptop??
    Thanks
    I live my life quarter mile at a time, For those 23 Seconds nothing else matters
    vs ss
    Oct 2007
    Does it feel warm, sometimes they turn off when hot.
    When you have it on try to have it elevated so the fan can get good circulation.
    No computer geek, but just something I picked up with works laptops.
    If your going to burn the aussie flag please do us a favour and wrap yourself in it first
    VS UTE
    Jan 2008
    nuh its not because the computer is hot,
    although i think it might be heat related, as that would explain why the longer i leave it off, the longer it will stay on when i turn it back on
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    First and easiest thing to look at would be dust on the intake and outtake vents. If you have access to compressed air a quick shot in the vents can help.
    calais4life is offline calais4life!
    calais
    Aug 2009
    Belmont
    yeh i think coz it gets hot, dont 4get laptops got a fan to cool it down aswell so maybe ur fan isnt workin all sudden?? :S is ur laptop old?? open it up, turn on and see if the fan works.
    good luck mate
    Got a Sv6 vz ute, so is the calais vz
    and they both for sale
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I had an iMac that did the same thing. Sometimes it would last days before turning itself off, sometimes it was minutes.
    Turned out to be a dodgy power supply.
    Given that you've found it won't boot unless you have both the external power and the battery, it's looking like the power/charging system circuit is the culprit. Logically, it can't be the battery itself, or the power supply, because then you'd expect it to work with one of them removed.
    If you're electronically minded you could try dismantling and inspecting for dry solder joints or damage around around the power components on the motherboard. Other than that you may just have to cut your losses and get a new laptop. With the rate at which computers move, it's usually not economical to repair laptops if they develop a serious fault.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VS UTE
    Jan 2008
    uh its not old, about 12 months
    VT V8 Calais
    Mar 2007
    VS UTE
    Jan 2008
    just pulled it apart and cleaned heat sink, didnt help though
  1. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  2. upgrading our laptop
    By big m in forum The LAN Lounge
    Last Post: 24-03-2009, 10:48 PM
  3. laptop
    By shonky12 in forum The LAN Lounge
    Last Post: 11-12-2008, 11:54 AM
  4. f/s laptop in adelaide sa $500 neg
    By lord_davros in forum Parts And Other Items For Sale
    Last Post: 17-02-2008, 11:04 PM
  5. Free Laptop??
    By NORTI in forum The Pub
    Last Post: 10-12-2007, 02:22 PM
