Results 1 to 20 of 20
Thread: nero burn rights!!!
    VS UTE
    Jan 2008
    Angry nero burn rights!!!
    When i try to burn cd/dvd's with nero 6 it tells me to get my administrator to configure it to allow me to write cd/dvd's
    I have administrator right!!!
    I have tried it by logging on to the real admin account (Through safe mode)
    i have configured it to allow everybody to burn
    i have tried uninstalling, running nero 6 cleaner and then reinstalling,
    i have no other burning or iso software that could interfere
    I have tried other burning software but my cd/dvd writer dosent show up, just image recorder,
    strangely though if i install nero, then launch it straight away my dvd writer appears, however when i go to burn the disk it says "diskj failed" immediatly, and then once i relaunch nero my dvd drive s gone, and only the disc image is availible
    I live my life quarter mile at a time, For those 23 Seconds nothing else matters
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    sounds like a faulty dvd drive
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VS UTE
    Jan 2008
    i got it to burn 1 last week... i uninstalled all other dvd programs then reinstalled nero and dvd shrink then burnt it via dvd skrink
    Jun 2008
    golden beach
    Quote Originally Posted by Razor- View Post
    so it will only work with dvd shrink ?
    get another version of Nero i use perineum 7 still it still seems to be the most stable and when un installing nero use the nero cleaning tool
    VS UTE
    Jan 2008
    it wont even work with dvd shrink now (since dvd shrink burns through nero)
    I have also tried nero 9 but it kept saying nero burn rights wasnt even installed, even when i selected it as one of the extra things to install with nero,
    i shouldnt even need burn rights because i have admin rights..
    Jun 2008
    golden beach
    its the way its made it realy has nothing to do with admin right on ya pc like i said go for nero 7 premium preferably the reloaded edition
    VS UTE
    Jan 2008
    just installed nero 7 premium reloaded edition and its still only showing the image recorder
    VS UTE
    Jan 2008
    when i go into nero drive speed it says "no cd rom devices found"
    Jun 2008
    golden beach
    well in that case i have no idea
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    does ur drive appear under my computer?
    if not, its corrupted the driver in the reg.. i do have a reg hack but cant find it atm
    VS UTE
    Jan 2008
    nuh its in my computer and device manager,
    it can read fine.. its a software problem, not hardware, im sure...
    il try booting off an external hdd that has nero later and see if i can burn off that?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u dont have a copy of roxio by any chance u can try?
    even try turning on windows burning n see if u cant cook a cd.
    VS UTE
    Jan 2008
    windows burning?
    nuh i dont have roxio, but im sure i could "aquire" it?
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    known V6 issue (it happened to me)
    upgrade to V7
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
  15. #15
    VS UTE
    Jan 2008
    Quote Originally Posted by Smitty View Post
    upgrade to V7
    um if u read the post's you would also see i have tried nero 7 premium, and its only displaying the image burner (no burn rights problem though)
  16. #16
    VS UTE
    Jan 2008
    alright, now nero shows my recorder if i have a non blank dvd in it, and i can transcode and shit, but then when it tells me to insert a disk it is saying the drive is empty,
    also on dvd shrink if i load a disk image from my computer, it asks where i want to burn it, and shows my driver, if i select it it does the transcoding etc then says the disk drive is empty, just like nero
  17. #17
    '96 VS Commodore Equipe Sedan
    Apr 2009
    Hi Razor, I have come across this same problem on a computer that was used for video editing. Although it was not using Nero, the symptoms were the same. I tried just about everything to fix it as I also thought it was a software issue. I tried another DVD burner and it all worked fine after that.
    Just because it says it working correctly in device manager, it could still be faulty... a false positive if you like.
    Something else you could also try is checking that the cables are seated properly. SATA drives are the worst for the DATA cable popping out of its socket. If yours is not a SATA then just pull the ribon cable out and reseat it and also make sure the power cable is seated properly.
    I hope this helps
    Cheers Rossbx
  18. #18
    Jun 2008
    golden beach
    i suggested the drive to lol maybe he will listen to you
  19. #19
    '99 VT
    Nov 2008
    south east melbourne
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    nero icon...right click properties - admin rights / apply..
    driver update???
    google "nero 6 disk failed"
LinkBacks (?)
  1. 29-08-2009, 10:43 PM
  1. Do i need to pay her? My rights?
    By adamc11 in forum The Pub
    Last Post: 30-11-2008, 08:52 PM
  2. Cityrail Guards - Rights?
    By TVR-190 in forum The Pub
    Last Post: 08-09-2008, 05:31 PM
  3. Land Rights
    By hsvpunk in forum Jokes/Humour
    Last Post: 17-06-2008, 08:29 PM
  4. Our Working Conditions And Rights.....
    By Hairy Eater in forum The Pub
    Last Post: 25-03-2006, 09:00 AM
  5. Red and green, next episode..Burn BAby Burn
    By The1985divo in forum Jokes/Humour
    Last Post: 08-08-2004, 09:01 PM
