Results 1 to 9 of 9
Thread: Reprogramming EPROM's
    '96 VS Commodore Equipe Sedan
    Apr 2009
    Default Reprogramming EPROM's
    Just wondering if anyone here knows how to reprogram an EPROM or BIOS chip. I have an Old Soltek SL-85DR2 motherboard here that was working like a charm up until I flashed the BIOS and killed it . The BIOS update I installed was corrupt unfortunaqtely. I have a new eeprom and the correct BIOS update for the board now; I just need to have it reprogrammed.
    I know there is equipment available to do the job but in reality it is a bit expensive for a once off job
    Any assistance would be appreciated.
    Thanks Guys and Gals
    Rossbx
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i can most likely do it what size chip are we talking about can do 27c020 and bigger 32 pin
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Apr 2009
    Quote Originally Posted by delcowizzid View Post
    I am not sure of the size as you put it but the numbers on the chip I have here is as follows;
    SST
    49LF002A
    33-4C-NH
    0323052-A
    The original one out of the board has the following on it;
    SST
    49LF002A
    33-4C-NH
    209195-A
    in ballpark figures, the chip measures approximately 11mm x 14mm and is 32 pin
    I hope that helps...
    The chip measures 11mm x 14mm and is 32pin
    в∞ѕтεכ √&
    Jul 2008
    NZ
    4 sided chip is it i may be able to do it havnt done one before but my programmer supports it .lukes one should too i bet he has the same one i have
    Apr 2009
    Yep, 4 sided chip...
    If you want to have a crack at it, I will post it to you: just let me know
    в∞ѕтεכ √&
    Jul 2008
    NZ
    im in nz but more than happy to have a crack LOL they are reprogrammable so you could send your bad one even if you wanted i should be able to reprogram it if it only has the wrong file on it ill pm my address
    в∞ѕтεכ √&
    Jul 2008
    NZ
    can you not flash it in directly via floppy drive should be able too thats how i did mine ages ago
    Apr 2009
    Yes that is how it is normally done, but since the corrupt BIOS was installed, it won't post. The CPU fan spins but that is about all that happens...
  1. reprogramming key
    By sloo3l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2009, 02:21 AM
  2. VZ ECU Reprogramming
    By rebecca22 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-04-2009, 12:37 AM
  3. VZ Key Reprogramming
    Last Post: 25-04-2009, 06:09 PM
  4. Reprogramming Keypads
    By scozzman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 11:02 PM
  5. Reprogramming Memcals
    By VpV6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-05-2005, 10:15 PM
