Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Accidentally deleted sound driver....
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    Default Accidentally deleted sound driver....
    Was going through all my unused programmes, and doing a bit of spring cleaning. I deleted some program called VIA HD Audio Deck. After that all the sound stopped working, nothing coming out of the speaker or headphones. I did a bit of research on the net and found out that I must have deleted a sound driver, but how do I get it back? I've gone through some of the windows cd's and can't seem to find one that has sound card drivers on it. Just wondering if anyone knows where to get them from, without having to pay for them once you download a program and it does 3/4 of what you need then asks you to give them money. Cheers
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    If you have your motherboard driver disk, use that. Second option is try doing a windows update, they usually have drivers for random hardware. Otherwise go to you computers manufacturer's website, type in the model and get the sound driver from there.
    What's the make and model of your computer?
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Quote Originally Posted by burnz View Post
    Had a look on the link but couldn't find anywhere to download their software. I managed to download the program again, but installing it is where I get stuck. It comes with a redme.txt, but the instructions are above my computing knowledge. I have underlined the section that I am stuck on....
    . Import driver components
    (1) Copy all the files to a directory, e.g. "D:\VIADRIVERS\VIAHDUAA190a\".
    (2) Create a directory, e.g. "D:\VIA_Repositories\", if there is
    none.
    (3) Open Component Database Manager under Microsoft Windows
    Embedded Studio
    (4) Click on the "Repository" and then "Repository Roots..." buttons.
    Type in the complete path of the repositories directory,
    for example "D:\VIA_Repositories\". Click on the "Add" button
    and answer "Yes".
    (5) Click on the "Database", "Import...", and then "..." buttons.
    Navigate to directory "D:\VIADRIVERS\VIAHDUAA190a\" and
    then choose the .SLD file. Next, pull down "Repository root"
    drop-down and select "D:\VIA_Repositories\". Click on the
    "Import" and then "Close" buttons to close the dialog.
    (6) Close the "Component Database Manager".
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    Can't you just restore the file from your trash bin after you deleted it..unless you emptied that out aswell??
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
    betts's Avatar
    Built toyota surpa
    Nov 2005
    May 2009
    May 2009
    Drivers - Download
    theres another link thats not for vista and is the hole audio package.Good luck hope any of that can help ya!!
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Awesome mate, I'll give them a try and see what happens, will let you know
    May 2009
    np's m8, hope one of them works, nothing worse than friggin comp problems!!!
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by betts View Post
    top of page (support>drivers) select softwear.http://www.via.com.tw/en/support/drivers.jsp
    try looking a little better at the site
    Powered By Garrett
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Have downloaded several versions of the program and none of them have done the job, either I have got the wrong ones or I am no good at installing them. I think I'll just call microsoft and see if they can help me over the phone. Cheers for all the help
    The Blues Mobile
    Dec 2008
    Western Sydney
    Microsoft are useless at that and they might charge you for it. Just let me know what is the make and model of your computer, or is it a custom built?
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Uh I have gone into system properties, and this is what it says:
    Microsoft Windows XP, Home Edition, Version 2002, Service Pack 3.
    Computer: Intel(R)
    Celeron(R) CPU 2.66GHZ.
    Is that what you need?
  15. #15
    The Blues Mobile
    Dec 2008
    Western Sydney
    No that's not it. Is this a branded computer, like DELL or HP? Or did someone build it for you?
    Take a picture of you computer. If it is a custom built then take a high res picture of your motherboard (take the side cover off) and i'll work it out.
  16. #16
    betts's Avatar
    Built toyota surpa
    Nov 2005
  17. #17
    betts's Avatar
    Built toyota surpa
    Nov 2005
  18. #18
    The Blues Mobile
    Dec 2008
    Western Sydney
    Ok so your Mother Board's model is Gigabyte GA-VM900M.
    This is the right driver for that motherboard (assuming you have: Windows XP, and you do not have another sound card (could not see one)): http://Asia.giga-byte.com/FileList/D..._via_hypro.exe
    Otherwise this is the page for it: http://www.gigabyte.com.tw/Support/M...t=xp#anchor_os
    Try this first if it still does not work than it's not your driver but could be a setting.
  19. #19
    betts's Avatar
    Built toyota surpa
    Nov 2005
  20. #20
    The Blues Mobile
    Dec 2008
    Western Sydney
    Also buy yourself some cans of compressed air and get all that dust out between the CPU Fan, otherwise there is not enough cooling (don't use vacuum cleaner!).
  21. #21
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Just do a system restore on your pc till before you deleted the files.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
  22. #22
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by sircruisealotVS View Post
    He uninstalled it, which means he deleted the files. System restore does not restore files you've deleted, only settings.
  23. #23
    betts's Avatar
    Built toyota surpa
    Nov 2005
  24. #24
    The Blues Mobile
    Dec 2008
    Western Sydney
    Alright, take a screen shot of this and let me have a look: Go to Start > Control Panel > System > Hardware > Device Manager
  25. #25
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Ok I'll upload pictures this way because it's quicker.
    Attached Thumbnails Attached Thumbnails Accidentally deleted sound driver....-screenshot.jpg
  1. sound system help, sound changes in middle of song!
    By Summer-Sickness in forum Car Audio
    Last Post: 13-04-2009, 02:54 PM
  2. Sound System high pitch sound
    By liquidforce_134 in forum Car Audio
    Last Post: 16-07-2008, 10:31 PM
  3. SS to US accidentally confirmed!
    By Evman in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-01-2007, 12:18 AM
  4. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
  5. Deleted
    By DVL2C in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-01-2004, 08:35 PM
