Anyone an Outlook guru?
I want to send a fax from outlook using a network all-in-one printer. I have added the Fax Transport feature, but I'm buggered if I can get the computer to find the all-in-one. I can run the modem wizard, but it won't find anything. I am just about to run the install disc for the all-in-one on this machine to see if that helps. Any other suggestions?
What model is the all-in-one???
Try reinstalling the software & drivers for your printer.
CHECK OUT MY RIDE
IF I WAS HELPFUL TOO YOU CLICK MY SCALES
"Girls are like domain names, all the good ones are taken."
Doing that as we speak.
It is a HP Laser Jet 3055.
Tried installing the drivers again, but since the printer is on a network, my PC can't find it. The network is wireless, but the installation wizard for a fax modem does not give me the option for that, only a data connection between two computers.....
idk if you can but when i have to install mine a ethernet cable has to be plugged directly to pc then once its done i can just yuse the witreless network settings
Originally Posted by Smidy
I'm thinking I will have to have it plugged in via an ethernet cable.
