Results 1 to 11 of 11
Thread: Somthing like driver detective?
    VS ute
    RefleX v1.2 Champion!
    Aug 2009
    Default Somthing like driver detective?
    Hey,
    Is there something like driver detective but free?
    Ive been having some driver related problems and i cant "acquire" a full copy of driver detective. But i scanned with the free version and im missing 6 drivers and 4 are out dated..
    My 5SPD VS UTE!! Now wrecking
    Quote Originally Posted by Grennan View Post
    Aggravated Burnout.... How is that different to a normal burnout, does the guy have a frowny face? Seriously get ****ed.
  2. Default
    what problems are you having? those programs are always going to report problems because they want you to purchase the software. i know that my computer is perfectly fine, but i once did a 'scan' of my computer just to see what it would say, and check this out:
    that is absolute bullshit . not that i need to go into every one, but startup bottlenecks... i manually configure what runs on startup using msconfig, and i've disabled nearly everything. so it's just complete bullshit really. do a fresh install of xp with no devices attached and no software installed - i bet it'll still say you've got problems.
    any drivers it uses will be available somewhere on the net for free anyway, so maybe we'll be able to help you out
    Quote Originally Posted by zai View Post
    I am not sutpid
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Quote Originally Posted by Jamie-b View Post
    Hey,
    What operating system are you running?
    VS ute
    Aug 2009
    yer ok thanks,
    Im having problems woth my sound.. and by problms i mean i have none..
    since i downgraded from vista to xp about 18 months ago ive had problems, i fixed it by installing sound drivers from a different machine, but i got windows errors about sound and got sick of it so i uninstalled it and installed the correct drivers from the Toshiba website, but i still had nothing, so i uninstalled them and tried installing the ones from the other machine on it, but its telling me its an older version and wont let me so now i have no sound..
    But im having other problems like nero wont detect my Cd/dvd drive as a burner, just a writer, and ive tried many different nero versions and other software, but if i re-install it works once then it wont work again or somthing like that,
    i cant run chkdsk and i have an empty folder i can delete which is on my desktop so i get a system popup saying to run dskchk because theres a problem, but when i try to run chkdsk it says "windows was unable to complete the disk check" straight away..
    On startup i get lots of things coming up asking if ide like to connect to windows live updates to find the correct drivers or somcrap...
    I think ill just do a fresh install....
    Is there a way i can backup all my windows updates so when i re-install XP i dont have to re-download em all?
    VS ute
    Aug 2009
    Im runnng Xp sp3
  6. Default
    sounds like it's reformat time , that's the easiest thing. unfortunately you can't back up the updates though, but yeah i'd give that a shot first.
    I am not sutpid
    VS ute
    Aug 2009
    Im trying to back up all my stuff, but when i plug my external HD into the compiter i just get "usb device not recognised"
    VS ute
    Aug 2009
    Now ive got it to be recognised in Device manager as "usb mass storage device" but it isnt showing in my computer...
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    i use Driver Genius. its really good and easy to "acquire"
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    may need to be formatted. get a live linux distro and format it through there. also try different usb ports, and different cables.
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    Quote Originally Posted by RufusŪ View Post
    I second this. I recently bought a printer and a 3m USB printer cable to go with it. Took it home and installed all the software and drivers on the computer then connected the printer to my computer via the USB cable only to get an error. I then tried it on another machine and got the exact same problem. Swapped the cable over to an older 2m USB printer cable I had lying around and works no problems. I should probably get back to that computer shop (MSY) and let them know that that particular printer will not work with the 3m cable they sold me.
  1. ever done a mod to somthing that wasent a car??
    By woodywoodpeckerin02 in forum Jokes/Humour
    Last Post: 19-08-2009, 08:45 PM
  2. Replies: 10
    Last Post: 18-03-2007, 05:25 PM
  3. astra somthing different
    By burnz in forum General
    Last Post: 11-07-2006, 06:49 PM
  4. chinese detective
    By bencom in forum Jokes/Humour
    Last Post: 26-04-2006, 10:28 AM
  5. Detective training
    By Mungar in forum Jokes/Humour
    Last Post: 15-07-2005, 09:12 PM
