Does XP have a temperature / CPU load monitor?
I had a look at the device manager and also system tools but can't find it. Thought I saw it some where once but????
Thought it might be on CPU-Z but nothing.
If not is there a free program that shows CPU temp similar to the layout of CPU-Z?
I use a program called Core Temp, havent used the other program you mentioned so dont know if it's what you're after?
It's a free download aswell.
Core Temp
hey mate, made by the same company as cpu-z .. called CPUID hardware monitor.. gives all temps fan speeds and voltages.
Thanks for your help.
Good progs
Very impressed with "Everest Ultimate" thanks.
looks like you've already found what you're looking for, but just to put it out there i use speedfan. it's a very light app that does exactly what i want it to do. monitors cpu usage/temps/hdd temps/controls cpu fan etc, and it's not bulky like a lot of other applications.
Thanks levy, I'll check it out.
I use PC Wizard. Shows all the specs on every part of your pc, aswell as temps and loads
Originally Posted by davway
