Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: wireless modem help
  1. #26
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    You need to open up your internet browser.
    In the address bar you need to type 192.168.1.254 and press enter.
    This will take you to the login page for your modem. It might ask for a username and password.
    this is usually just admin for username and password is just admin as well.
    Once you get into the main page of your router, click on "Interface Setup" under there click on the heading "Wireless".
    Access Point = Activated.
    Channel ID = Australia
    Channel = Usually Channel 6. 1, 6, 11 are the most common used.
    SSID = (Enter the name that you want to call your wireless network).
    Authentication Type = WPA-PSK and WPA2-PSK
    Pre-Shared key = Enter a password for your network. Use letters and numbers and make it something hard.
    Leave all the rest of the settings as their default values.
    Save Settings.
    You now should have a secured wireless network.
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
  2. #27
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Thanks holdensupporter. I just did that and then put the code into my 2 lappys. Both are now on the net wirelessly. I couldnt work out the authentication type, that is why i couldnt put a password in before.
    Should i do anythng else to secure it? ie the encryption.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
  1. Problem with modem/internet
    By BOGANV8 in forum The LAN Lounge
    Last Post: 02-02-2009, 10:41 PM
  2. Issues with modem
    By AirStrike in forum The LAN Lounge
    Last Post: 25-08-2008, 12:41 AM
  3. Wireless Router/Modem suggestions
    Last Post: 09-08-2008, 09:56 PM
  4. Good modem/router for ADSL2+
    By Shounak in forum The LAN Lounge
    Last Post: 12-07-2008, 01:49 PM
  5. dial up networking modem prices
    By shonky12 in forum The Pub
    Last Post: 07-01-2008, 02:38 PM
