+ Reply to Thread
Results 1 to 15 of 15
Thread: LAN only working after a PC restart
    Grennan's Avatar
    Grennan is offline Justice League Grennan Senator Grennan Senator Grennan Senator
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Default LAN only working after a PC restart
    Ok... Finally fixed my issue with my Xbox getting onto Live. Now it seems I have a totally different issue.
    It seems the Xbox only wants to connect to my LAN (through Internet Connection Sharing) after my PC has been restarted. AFAIK ive enabled it so that if my PC is in standbye or inactive, the Xbox will wake it up. The problem is rarely is it an issue of my PC being inactive, as soon as I turn the xbox off I wont be able to reconnect it.
    - Black Manual VX SS Series II -
    Bagged on Red and Black 20's!!
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    stop being a cheapskate and just buy a switch! seriously its less than 50bucks....see
    CentreCom - Cheap Notebooks & Computers
    try one of them out.....should solve your dramas and means that you can add other devices later on if need be!
    or something like this
    allows you to add wireless devices later on....
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    For some god forsaken reason my Modem wont connect to my PC via Ethernet. Trust me. I tried the switch.
    Aug 2009
    how old is this computer??? have you tried a dlink network card or something??? try putting something like that is as well....just to run the ethernet! just an idea!!! sorry about the last post, after i read it i realised i sounded like a real ahole!
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    The computer is not old at all. It has two network cards. One is inbuilt so its a nvidea card and the other I recently purchased specifically for ICS because the switch didnt work which is a Realtek card.
    Ive used the modem as a USB modem for as long as I can remember. Ive uninstalled the USB drivers and gone through the software steps to enable Ethernet but it doesnt want to work - thats on both Ethernet connections. So i dunno if its a case of the Modem being a pain in my ass or the PC doing something ####ing stupid. Im going to say its my PC because my old computer (same modem) had no issues whatsoever with ICS.
    At the moment my work around is restarting my PC everytime I want to play on XBox live - which after 1 day is getting tiresome.
    edit
    Ive just been told that I need a router, and it wont work on a switch because its a cable modem *shrug*
    VT V8 Calais
    Mar 2007
    So the modem is not ADSL?
    Are there network ports on the back or is it USB only
    50LTRv8
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    Its a Cable modem. I run Optus Cable.
    There is a Ethernet port on the back as well as a USB. When I connect it, it...kinda recognises it, it says there is limited or no connectivity - aka shit doesnt work.
    VT V8 Calais
    Mar 2007
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    This is what is listed in network connections:
    Motorola SURFboard SB5100 USB Cable Modem
    Aug 2009
    well by rights a router without a modem should solve your issue, because you have the cable modem, a router can then deal with the connection to the modem and the router can therefore deal with the IP addressing for its own network......that should work...theoretically anyway! try that Linksys wireless router or something similar if you are willing to spend some money, or find a mate who has one that you can steal for an afternoon!
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by Grennan View Post
    When you use the ethernet ports, you would have to set ip addresses on the port on the modem and the port on ya comp, can you get to those settings on the modem using the USB connection via a management page?
    50LTRv8
    Aug 2009
    when it is saying that it means that the optus cable modem is not assigning the IP addresses, it is not becoming the DHCP server to auto assign the IP addresses, if you can create a static route between the modem and a switch that is running the PC and XBOX, if you want to have the network running as it should (using IP addressing!) that should work, the reason its not working is because you have all the data travelling out the USB on the modem, by getting rid of that you should end up with a more stable (speed and uptime) connection because you are using the correct format of cable for a network!!! oh it might also work if you get a PS3!!
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by schrinky View Post
    I am pretty sure this modem does NOT have routing functionality, therefore he will not be able to do as you stated.
    50LTRv8
    Auzziephoenix's Avatar
    Auzziephoenix is online now Typical P Plater Auzziephoenix Executive
    Shanghai VZ Calais
    Jul 2009
    Have you tried connecting the Xbox directly to the modem?
    If that works, then connect the PC via USB, and xbox via ethernet.
  15. #15
    Aug 2009
    Quote Originally Posted by 50LTRv8 View Post
    it shouldnt matter, due to the fact that the modem will only be having to assign an address to itself and the other end it shouldnt make a difference, the same thing would happen when the PC is connected to it......the point of a router is to create a separate broadcast domain, effectively the modem connection to the router is one broadcast domain and the network that is running out of the router is another broadcast domain, so the modem only has to deal with itself and getting data to the other connection beyond which it doesnt need to know! all you have to do is set up a default static route so that all information that is no destined for the routers direct network is set towards the other end connection which is the modem and then the modem deals with all the data packets from there on......bahhh sorry i stated switch, not router........a switch cannot define a DHCP your correct!! but a router can!!
+ Reply to Thread
  1. VT Just dies and won't restart
    By phantz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2010, 01:54 PM
  2. VS stalled and could not restart
    By davros in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2008, 05:04 PM
  3. How Do i restart the computer on the vn ?
    By Ygoford in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2006, 01:05 AM
  4. Engine dies on warm restart
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 07:27 PM
  5. vs cuts out when driving and is hard to restart
    By spazgazz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2005, 12:29 PM
