Results 1 to 13 of 13
Thread: help. new motherboard isntall.
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Default help. new motherboard isntall.
    just had to install a new motherboard.... now im pretty sure ive got things plugged in properly well accoring to the back to front diagrams..... when i power the pc up it goes fine until it comes up with the safe startup etc screen. after i click start windows normally, it reboots. keeps doing this over and over. what have i done wrong???
    cheers,
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    You Can't swap over the motherboards and expect windows to load. You will only be able to do that if it is the same board. It is blue screening every time windows tries to load. (some time you get lucky and it will work) Hense the Looping you are experiencing.
    Format and Re-Install will solve your problem.
    Every time you replace major hardware inside a PC (mainly the Motherboard) you will have to re-install windows as windows more or less sets it self up according to which board you have in your system. If you replace the board windows tries to load to something that isn't there and has a heart attack.
    If you do not want to loose your data purchase a new hard drive and have your original as a secondary.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You have most likely installed the motherboard correctly.
    As said its a Windows error not recognising the motherboard.
    What version of Windows is it?
    XP: Run the install disk, skip the first repair option, but use the second one (automated repair) it will most likely fix the issue without losing any data. If it fails then a full re-install is in order.
    Windows 7: It should pick it up and work fine, may need to run the disk for a driver.
    Vista: NFI, Vista is to frustrating.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VX Series II S Pak
    Mar 2009
    South Western Sydney
    should be able to get away with a soft install on the hard drive to get it repaired and working as stated above should be no need to reformat the hard drive and lose your data completely. if not and you need to reformat make sure when you do split your hard drive in 2 partitions one smaller then the other just enough to fit the install of windows that way if this every happens again you dnt have to lose all your data and you just have to format the windows partition (smaller one) just be sure if you do that all installed programs and everything else is installed on the larger partition.
    If it weren't for my lawyer, I'd still be in prison. It went a lot faster with two people digging
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    you wont need to format m8, you can change any part u want u wont need to format..only thing that u would most likely have to do is just re-activate it with the serial thats it!!
    id say make sure ur psu is plugged in correctly, and also checked ur temps in bios, would could be another problem that i had with a customer of mine...booted up fine, loaded windows then bam turned off repeatably,
    also did u reapply new thermal grease?
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    XP is Hardware Specific. I See this every day and explain this to clients daily.
    IT is pretty well documented.
    Google
    Oh and also Virus that corrupt the Boot Files will cause windows to loop at the start.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by S.T.K.E View Post
    Google
    You give IT advice for work?
    I love you sort of guys, give shit and misleading advice, customers get fed up with it, and come to me
    S.T.K.E's Avatar
    Mar 2009
    Brisbane Northside
    Quote Originally Posted by Tom_1569 View Post
    I'll Keep that in mind when i sell my monthly 40 Foot Containers .
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    lol ok.......
    VX Commadore
    Jul 2010
    Parramatta
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Probably a software issue in relation to the new boards hardware, however you might just be better off reformatting and putting on a newer OS.
    VT Commy
    Mar 2010
    Adelaide!
    I'd try and reformat. No need for a newer OS either, if you're happy with what you've got.
  1. Motherboard repairs
    By Rossbx in forum The LAN Lounge
    Last Post: 24-07-2010, 06:37 PM
  2. PCI-E2 gfx card in PCI-E motherboard
    By Jesterarts in forum The LAN Lounge
    Last Post: 17-04-2009, 08:09 PM
  3. motherboard
    By shonky12 in forum The LAN Lounge
    Last Post: 15-12-2008, 12:46 AM
  4. motherboard
    Last Post: 02-12-2008, 07:05 PM
  5. 865gdmp motherboard questions
    Last Post: 21-10-2008, 10:26 AM
