Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Astranomical
Thread: PC dead. MoBo or power supply?
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default PC dead. MoBo or power supply?
    I went to use my computer last week and it's usually left switched on but this time it was off. I tries the switch to no avail and I checked all the connections and they were fine. I assume it's either the power supply or the mother board. Is there any way to check or am I just better off taking it in to get fixed?
    Cheers.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Try this, I follow these steps every time i want to fault test a system that doesn't boot,
    Signature Goes Here
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VY S
    Apr 2011
    Sydney!
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VY S
    Apr 2011
    Sydney!
    Sounds like the power supply - do you have a old PC with a spare PSU that you could wack in to test it??
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Don't worry about that for now, you don't need the drives connected for the machine to POST and come up with the BIOS boot screen. As long as its powerful enough for the parts in your system, and so long as it has all the correct connectors (which it may or may not depending on the age, power supplies made prior to 2005 will usually have a 20 pin ATX connector, rather than the 24 pin connectors used in most systems today, and power supplies made prior to 2002 will not have an ATX12V connector (the smaller 4 pin connector with the yellow and black wires that is separate to the main ATX connector)
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    VY S
    Apr 2011
    Sydney!
    Quote Originally Posted by Astranomical View Post
    I don't think I could have said that better!!
    Only other thing I might mention, make sure everything is plugged in internally..
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Sounds like PSU, but.... take the ATX connector off from the motherboard, grab a paperclip and put it into the green and any of the black earth wires. This should turn the psu On, and you can put a multi meter on the other pins to check if its live, or just ensure that the psu is ON ( see if the internal fan is spinning).
    Also, many motherboards have internal power buttons on them, mine does (power + reset). try hitting one of these to see if it powers on.
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    My guess is PSU, though it could be both. I.e, PSU blows and then takes mboard with it, I've had that before.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    VT V8 Calais
    Mar 2007
    Hey Troy, if you want me to have a squiz at this let me know, I only live round the corner
    50LTRv8
    NV-MY-VT's Avatar
    NV-MY-VT is offline Sleeper Builder
    VT 2000 Olympic Edition
    May 2011
    Mornington, Victoria
    It's gotta be the PSU... Or even just the power button.
  1. power supply on my VT
    By vtcomowner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2010, 10:31 AM
  2. Problems with power supply
    By 271207 in forum Electrical Wiring / Questions
    Last Post: 28-10-2010, 02:13 PM
  3. Broken Power Supply
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2008, 11:52 PM
  4. power supply to amp with no fuse
    By Dr.304 in forum Car Audio
    Last Post: 26-04-2007, 03:18 PM
  5. Power Supply to amp in boot.
    By Dolly in forum Car Audio
    Last Post: 22-04-2007, 03:48 AM
