Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree4Likes
Thread: Internet not Working. Please help.
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    Exclamation Internet not Working. Please help.
    Hellooooo everyone,
    Last night got home (my computer has been playing up a little for a few days) and my internet connection to the computer is not working (my xbox live is so it can't be the internet itself).
    Ok so the first thing i did was a system restore that achieved nothing so i put it back to where it was. Now i done all of the simple stuff, reset everything check the cables are fine and what not, This also achieved nothing.
    I started going through the windows trouble shooter starting from the top, Disconnecting/reconnecting everything but nothing seems to work. I got upto the run: command, /ipconfig and my IP address came up as 0.0.0.0 to start with is that normal? done the /ipconfig release, ipconfig renew. The ip release came up that it was already released and the ip renew came up that it is not possible.
    now basically i want to know do i run it to a computer shop to get it fixed or is this something you guys can help me with. I was playing with it for around 5 hours yesterday (so im pretty over it!) Now, Where the plug goes into the back of the computer it is flashing (green) and that tells me that im getting connection through the cable, right? so there has to be something wrong with the computer itself?
    Also, I am unable to do system recovery, it tells me that there are no files to recover (or something around those lines) and i dont have any of the discs that it came with. Have had the computer a while and i believe they got lost a while back when moving!
    Can someone please let me know what to do, I dont want to take it down to the local computer guy if i can fix it myself!
    I'm clearly pretty basic on a computer so ANY help would be great!
    Thanks for looking and thanks in advance!
    Cheers, Mick. (on the work computer)
    I have given as much info as i can (remember).
    Edit: forgot to add, I ran:
    AVG: no resluts founds
    Ad-aware: 6 threats (removed all)
    and have no current fire wall set up.
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    Jaymz's Avatar
    Jaymz is offline Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    fire up your command prompt again (where you ran your ipconfig commands) and run this command:
    netsh int ip reset c:\resetlog.txt
    Post the results of the resetlog.txt here.
    The command will reset your TCP/IP stack.
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    ill duck home at lunch and give it a go and let you know what i get.. Cheers mate!
    So that will be a possible fix? or just maybe tell me the problem.
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    No problem! Tech shops can charge like wounded bulls so it is better to get free advice first!
    It definitely sounds like your PC is having trouble getting an IP address from your modem.
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    Yeah i know they do!
    Well if it helps over the last few days it been not loading certain pages (google, ebay, etc.) but sites like justcommodores.com and facebook have been fine. Than just yesterday it shit itself completely!
    Also, The 2 internet things (2 computers that pop up bottom right corner) the 1394 connection and the high-speed connection are both disabled not and 'fail to connect' whenever i try now.+
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    hmm ok, if you right click on High Speed connection can you select enable?
    It sound strange why some sites were working and others did not.
    Can you paste the results of the ip reset command i got you to run?
    Also, open the following file with notepad:
    c:\windows\system32\drivers\etc\hosts
    and paste the contents here
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    when you select enable it comes up connecting, then connection failed and does nothing!
    Also i have had something about system32 comes up as an error everytime i boot the computer up, but that has been happening for months.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I had a similar problem thought it was the network card so swapped it out, was still the same so wiped it all and installed windows 7 (had xp) all fixed now.
    Computers are a pain sometimes hope you get it sorted.
    ========My Statesman 20's Mafless and 3.9's========
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    the system32 errors can mean all sorts of things, we can sort that one out later.
    what is the make and model of your computer?
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    On my way home now! ill get back to you with these things!
    Thanks alot for your time Jaymz
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    uh the ####ing thing is working :S the first thing you sent me to do in the command wont work? it comes up with nothing when i type
    netsh int ip reset C:\resetlog.txt
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    and typing in c:\windows\system32\drivers\etc\hosts to open in wordpad (file does not exist).
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    is it possible that the first thing fixed it?
    Or what the #### is going on? afraid to turn the computer off now it may #### out!
  15. #15
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    hmm and hmm. What version of windows are you using?
    Try use notepad instead to open the file. if you navigate to that folder and open the file with notepad (double click on the file and it should ask what program you want to use to open the file)
    The other option is for me to take control of your computer remotely and have a look into it for you. <- that is completely optional though, privacy stuff and all that. Only if you are ok with me taking over your computer.
  16. #16
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    windows XP,
    Computer is a HP (ill get you numbers later gotta get back to work)
    This came up:
    # Copyright (c) 1993-1999 Microsoft Corp.
    # This is a sample LMHOSTS file used by the Microsoft TCP/IP for Windows.
    # This file contains the mappings of IP addresses to computernames
    # (NetBIOS) names. Each entry should be kept on an individual line.
    # The IP address should be placed in the first column followed by the
    # corresponding computername. The address and the computername
    # should be separated by at least one space or tab. The "#" character
    # is generally used to denote the start of a comment (see the exceptions
    # below).
    # This file is compatible with Microsoft LAN Manager 2.x TCP/IP lmhosts
    # files and offers the following extensions:
    # #PRE
    # #DOM:<domain>
    # #INCLUDE <filename>
    # #BEGIN_ALTERNATE
    # #END_ALTERNATE
    # \0xnn (non-printing character support)
    # Following any entry in the file with the characters "#PRE" will cause
    # the entry to be preloaded into the name cache. By default, entries are
    # not preloaded, but are parsed only after dynamic name resolution fails.
    # Following an entry with the "#DOM:<domain>" tag will associate the
    # entry with the domain specified by <domain>. This affects how the
    # browser and logon services behave in TCP/IP environments. To preload
    # the host name associated with #DOM entry, it is necessary to also add a
    # #PRE to the line. The <domain> is always preloaded although it will not
    # be shown when the name cache is viewed.
    # Specifying "#INCLUDE <filename>" will force the RFC NetBIOS (NBT)
    # software to seek the specified <filename> and parse it as if it were
    # local. <filename> is generally a UNC-based name, allowing a
    # centralized lmhosts file to be maintained on a server.
    # It is ALWAYS necessary to provide a mapping for the IP address of the
    # server prior to the #INCLUDE. This mapping must use the #PRE directive.
    # In addtion the share "public" in the example below must be in the
    # LanManServer list of "NullSessionShares" in order for client machines to
    # be able to read the lmhosts file successfully. This key is under
    # \machine\system\currentcontrolset\services\lanmans erver\parameters\nullsessionshares
    # in the registry. Simply add "public" to the list found there.
    # The #BEGIN_ and #END_ALTERNATE keywords allow multiple #INCLUDE
    # statements to be grouped together. Any single successful include
    # will cause the group to succeed.
    # Finally, non-printing characters can be embedded in mappings by
    # first surrounding the NetBIOS name in quotations, then using the
    # \0xnn notation to specify a hex value for a non-printing character.
    # The following example illustrates all of these extensions:
    # 102.54.94.97 rhino #PRE #DOM:networking #net group's DC
    # 102.54.94.102 "appname \0x14" #special app server
    # 102.54.94.123 popular #PRE #source server
    # 102.54.94.117 localsrv #PRE #needed for the include
    # #BEGIN_ALTERNATE
    # #INCLUDE \\localsrv\public\lmhosts
    # #INCLUDE \\rhino\public\lmhosts
    # #END_ALTERNATE
    # In the above example, the "appname" server contains a special
    # character in its name, the "popular" and "localsrv" server names are
    # preloaded, and the "rhino" server name is specified so it can be used
    # to later #INCLUDE a centrally maintained lmhosts file if the "localsrv"
    # system is unavailable.
    # Note that the whole file is parsed including comments on each lookup,
    # so keeping the number of comments to a minimum will improve performance.
    # Therefore it is not advisable to simply add lmhosts file entries onto the
    # end of this file.
  17. #17
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    would be happy for you to take over mate! you seem pretty genuine ill get back to you later!
  18. #18
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    The first fix/command that I got you to run would have reset all your network card back to factory standards. This process is a low level type reset which can sort a lot of problems. It should have fixed the issue, however without trying to replicate the problem (EG restart the pc) we wont know for sure.
    You "should" be ok to restart your computer, but before you do you should try run the ipconfig command again and let me know what comes up.
    Connecting up will be a last resort, some people can be funny about others looking at their computer so i have to make doubly sure you are ok with it. I will also show you how to disable the remote session and remove it once we are done.
  19. #19
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    I will be back home at about 3, Can i go through it with you then, sorry i only had a half hour break so didnt have to much time to play.
    I cant thank you enough for taking the time to do this mate!
  20. #20
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    no worries dude, always happy to help!
    Yea i dont finish work till 6pm NZ time (2-3hours ahead of you guys) so i can help out/connect up before i go home for the day. Just let me know once you are home/ready
  21. #21
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
  22. #22
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    could i also ask you to check a couple of other things while your at it? i dont mind if you dont have time, ill let you know what im talking about when you can see it!
  23. #23
    Jaymz's Avatar
    VS Exec 1996
    May 2005
    Hamilton, NZ
    sweet, so you are 2 hours behind me. that will mean it will be 5pm here when you finish at 3. Not a problem at all, can co-ordinate it through CB which will be easier. And if need be i can give you a call and talk you through some things.
    And yup, i can look at any other issues that you have!
  24. #24
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
  25. #25
    Pickle''s Avatar
    VE Omega
    Apr 2009
    Sydney, NSW.
    ipconfig :
    Ethernet adapter local area connecion 2:
    Connection-specific DNS suffix :Bigpond
    IP address: 10.0.0.2
    subnet mask : 255.255.255.0
    Default gateway : 10.0.0.138
  1. internet
    By shonky12 in forum The LAN Lounge
    Last Post: 09-07-2010, 04:46 PM
  2. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  3. Internet for PS3???
    By UNKNOWN in forum The Pub
    Last Post: 28-04-2008, 12:25 PM
  4. Need Some PC/ Internet Help
    By Pub247 in forum The Pub
    Last Post: 06-12-2007, 07:50 PM
  5. What the internet is for....
    By SilverCalias in forum The Pub
    Last Post: 17-03-2006, 04:27 AM
