Results 1 to 17 of 17
Thread: Power Supply Unit Problem.
    Grennan's Avatar
    Grennan is offline Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Default Power Supply Unit Problem.
    Ok couple of days ago i turned my computer on and there was a sound that i can only describe as grinding, comming from my PSU. When somethings not working right i did what ever other male does and gave it a bit of a tap. FIXED!
    Turned my comp off over night to see if it would do it again and, sure enough that sound returned, another soft tap and it went away.
    The PSU isnt old, its maybe 6 months old... so ive got no idea what is happening. Any ideas?
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Dirty fan?....
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VT V8 Calais
    Mar 2007
    It will be a failed ballbearing, the supply itself is fine, but the fans can fail
    50LTRv8
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    I thought it was a dirty fan as well, but i clean them pretty regularily.
    Friend also suggested a failed ball bearing. Whats the fix? New PSU or what?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Grennan View Post
    New fan in PSU. Legally you are NOT allowed to open the PSU up and it will avoid all warranty's aswell. The fan in the PSU is very easy to replace if your careful, abit of common sense really. They are normally a standard size fan, depending on the manufacturer.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Only problem is that with some newer PSUs, the wires for the fan are soldered directly to the board, rather than to a connector, meaning you'll have to have soldering skills to replace the fan.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    mm this could be an excuse to get an ultra super dooper cool looking case with a PSU.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    never really liked buying cases that come with psus, cos i have an innate lack of trust. usually the people that make them (unless it's like coolermaster etc) are case builders, and i'd rather know every $ i spend is spent on the psu itself.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by pow3rslave View Post
    I agree, I just bought a shaw case with a PSU, its for my nephew. If i knock the case or give it a whack on top, the whole computer turns off instantly, also takes two more reboots for it to boot the hard drive. Quality
    I bought 2 coolermaster cases, one for me and one for my brother. He got a PSU with his, its only 350w, but doest seem to be reasonable, but ill be upgrading it soon anyway to be safe. I just spent 130 on a Coolermaster PSU, and you can straight away see why its worth that. Its dead quite, and you plug in the connectors you need to the PSU, so you dont have a heap of unused wires laying around.
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Ha mines a Shaw case and PSU, good to see i got quality.
    39 bux from MSY? lol
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Ozzie_VT View Post
    lol its a wire inside touching the fan possibly the fans wire?
    That would be a tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick tick
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    it would be ticking really fast which sounds like a grinding sound unless the fans spinning slowly
    he mentioned that he tapped it before and the sound stopped... if it was a bearing the fan wouldnt be spinning at all when he tapped it?
  15. #15
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    True.... Check these now wires hitting it.
    By knocking it, it could move the bearing getting it to sit in a spot thats quiet.
    A wire hitting the fan is a fainter sound then a bearing,
  16. #16
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    Nah this sound is pretty loud and its definallty a grinding sound.
    And the case cost 70 thank you very much
  17. #17
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    haha you went all out on that one
  1. Broken Power Supply
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-12-2008, 11:52 PM
  2. constant power supply for head unit not working
    By ShIbBy_industries in forum Electrical Wiring / Questions
    Last Post: 18-06-2008, 09:10 PM
  3. VN: power supply - cooling fans for head unit
    By savage1987 in forum Electrical Wiring / Questions
    Last Post: 07-10-2007, 09:33 AM
  4. power supply to amp with no fuse
    By Dr.304 in forum Car Audio
    Last Post: 26-04-2007, 03:18 PM
  5. Power Supply to amp in boot.
    By Dolly in forum Car Audio
    Last Post: 22-04-2007, 03:48 AM
