Results 1 to 4 of 4
Thread: Buggered DVD disc repairs
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Default Buggered DVD disc repairs
    Howdy all
    I've got an entire spindle of DVD discs that is falling to bits, some discs have already had the plastic top layer separate entirely from the rest of the disc and on others you can see where they are starting to separate
    Managed to salvage a few of the ones that have just started coming apart of have minor signs of coming apart but does anyone know of any adhesives that would restick the two layers without eating through or affecting the data side of the disc ?
    If ignorance is bliss why aren't there more happy people around ?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    I wouldnt recommend using any adhesives...
    If you have some clear packing tape you can place the disk on a clean flat surface and run the tape across it evenly.
    Then carefully with a stanley knife cut round the disk and the centre.
    Once the excess tape is cut off, wave a nakid flame over to heat up the tape so it sticks to the disk better. (making sure you dont melt the tape)
    This is only a temporary solution to your problem, enough to let you get the data off the disk.
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    The only proper, reliable "repair" that you can do is to get any and all of the data on those discs backed up onto a more reliable form of media (such as a hard drive, or another CD or DVD) fast, before they disintegrate much more.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    May 2006
    That's what I've done with the ones that aren't totally broken yet but was sort of hoping the ones that have come apart entirely can be at least temporarily fixed so i can get the data off them
    Ozzie_VT, will try your method with one of the worst discs and hopefully that helps... Cheers....
  1. [Melb] VN-VS Live Axle disc to disc
    By Rzeractor in forum Parts And Other Items For Sale
    Last Post: 01-06-2008, 02:34 PM
  2. Fs: [vic] Vk Disc To Disc 3.23 Rear
    By synoptica in forum Parts And Other Items For Sale
    Last Post: 11-12-2007, 11:52 PM
  3. WTB handbreak cable for VL disc to disc
    By broadtail in forum Swap / Wanted to Buy / Trade
    Last Post: 13-07-2006, 10:29 PM
  4. VL disc to disc handbrake cable
    Last Post: 12-07-2006, 07:03 PM
