Does anyone know of a company that makes an all in one card reader that I can install in a standard front panel slot (either floppy drive slot or other). There is quite a few cameras/phones in the house and I refuse to install 500 different drivers and software to transfer files, but I want a permanent fixture not a USB hub (surprised how quickly you fill USB ports up).
Had a look through MSY's catalogue (they are close to me) but can't find anything.
Selling FG G6E Turbo and buying a N/A Supra
ALDI supermarket's $9.00
also instead of having different softwear for different phone's, buy a usb bluetooth $12.00 ALDI
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
you can allso buy a usb splitter 6 into 1
Powered By Garrett
Could'nt you just have a few extra USB hubs, like, could you say,
connect one of those hubs into the PC, then connect another one into the hub?
FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
http://forums.justcommodores.com.au/...ressively.html
make sure if your gunna buy a usb hub that you buy a decent one, the cheap ones make whatever is plugged in run slow etc.
Yeah just add more USB's. some run better than others. My printer has a bunch of different card readers so i don't have to plug anything else in. Doesn't help you though i guess.
I don't want to run a USB hub, I find the performance is deminished. Would rather run an internal drive like Banks posted.
I read the MSY price list again and seems im in luck. Internal 5.25" drive the same as the one banks posted. Problem solved!
you can definitely get pci usb expansion cards.
USB 2.0 PCI Card 5 Port (NEC Chip) [USB-UP205] - $27.50 : PC Case Gear, Quality case accessories and components
there's one, $29 for 5 usb 2.0 points
this place is good and quick delivery. prices are ok, but not msy-cheap, anyway here are their 3.5" bay multi card readers.
PC Case Gear: Card Readers
just know that sd card/ card readers aren't 100% compatible with sdhc readers/cards (sdhc cards = sd high capacity, generally >2gb)
