G,day to all!
Im in the middle of attempting *cough* to make a web page for my business, trouble is i don't have a clue as to how any of this stuff worksNow i found a web site that's been very help full in making your own web page using note pad but i am having problems when it comes to putting pics up! Hers an example=
The web site tells me in note pad to put this up=
<body>
<img src="chef.gif" width="130" height="101">
</body>
Now that image works on the page that i have made ect but when i try to put a different image up (one that i downloaded and saved) it wont display properly ( the outline of the pic is there but there is only a little broken box up in the top left corner) I think its because the image i have downloaded and save is a jpeg image and not a gif image?? any help would be great!
MY RIDE 96 calais
http://forums.justcommodores.com.au/...96-calais.html
ALSO MY 1972 VALIANT CHARGER IN THE BUILD
http://forums.justcommodores.com.au/...t-charger.html
Nevermind got the problem sorted![]()
MY RIDE 96 calais
Glad you got it sorted...
On a side note: Learn CSS.
aZk.
MY RIDE 96 calais
W3School is literally like the best resource for everything... (apart from the Java API)
CSS = Cascading Style Sheets. Once you know CSS, your webpages will benfit like 10fold.
Toms code is accurate... in regards to the link.
aZk.
MY RIDE 96 calais
lol i attempted to make my own got over it pretty quick wat program u using. i used blue voda i think it was called
MY VY SV8 HBD http://forums.justcommodores.com.au/...y-sv8-hbd.html
i agree and disagree..
1. I NEVER! and i repeat NEVER use programming aids which include dreamweaver and anyother program which does literally all the hard work for you.
It makes you a very lasy programmer. Bad.
2. Its good in terms of getting something half decent out quick..maninly in cvxvxvxvxvxvx(sp?)'s case.
3. If you want to take a new task on, learn the entire language. Not every tag and its attributes but its past, use, limitations and syntax. There is more to programming than just knowing how to make stuff come up. There is links between elements and a flow your code should demonstrait.
There is alot of rules to programming too... like how to set things out, what to use and when etc. These should be know!
AS for your picture issue. You have a few options.. ill rank them from hardest to easiest.
1. Make a PHP script to lookup the required pics and display them in a gallery by using xml.
2. use a CSS build gallery page
3. Use a flash gallery page
4. Make a new page, upload pics to that and then link to the page..like this:
Page1:
<html>
<head>
<title>Page 1</title>
</head>
<body>
<h1>This is the main page with a link to the other images page</h1>
<br/>
<a href="page2.html">Click Here to view my images</a>
</body>
</html>
Page2:
<html>
<head>
<title>Page 2</title>
</head>
<body>
<img src="imagessrc.extension"></img>
<!-- etc etc etc -->
</body>
</html>
Thats a really basic description of what ya wanna achieve...
aZk.
I am just following this tutorial
HTML Tutorial
Well.....i understood some of that..?
I also have 2 say that was an outstanding effort to write all that @ that time of night![]()
MY RIDE 96 calais
Why add another level of complexity when just first getting your head around html?
My advice would be forget about CSS, learn how HTML works first, then worry about styling (that can be achieved through strict use of html) later.
HTML is easy after 2 or 3 weeks of working on it. If you're wanting to make a photo gallery however, just using html is one of the worst options out there to do it. PHP is the easiest option, but again that's adding another level of complexity that will probably do your head in at this stage
MY RIDE 96 calais
Yeah dont worry about PHP or CSS yet, focus on understanding HTML, and get a good grasp for it.
Avoid using programs that do the code for, use notepad, its the correct way to learn.
That way if you get a fault you can debug because you understand the code.
Dreamweaver is an excellent program, and great for getting a job done quickly, but learn the basics first.
If you need any help keep singing out.
