Results 1 to 6 of 6
Thread: System Recovery
    '97 VS Commodore + '98 E36
    Apr 2005
    Default System Recovery
    I've got an Acer Aspire 5612 Laptop which i've had for over a year now and its manage to build up a few errors and viruses that can't be fixed easily and its driving me nuts and i really want to reformat the whole thing from when i first got it. Its got Windows Vista with service pack 1?
    I need to know if any-1 knows how to reformat/system recovery the whole laptop with out a CD
    -The laptop DID NOT come with it's own recovery cd set for some reason =/
    and i've tried using my g/f's recovery cd but no go =[
    thanks in advance
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    might be able to contact manufacturer with a serial or paperwork and see if you can get an oem copy.
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Are you sure the recovery software isn't on a drive partition? It's not obvious most of the time, but if you grab the manual off the web somewhere it should be able to tell you. My last two toshys and Dell all have recovery partitions.
    VS III S Yewt
    Mar 2008
    If you tried other people's recovery cd, it won't work mainly because it comes with different drivers as such.
    I also hope that your partitioning table and data are still somewhat intact or otherwise you may lose the recovery partition.
    Mods:
    - Clear headlights (Altezza)
    - CAI, 8mm spiral coil spark plug leads
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    You are correct, they don't come with Recovery CD's anymore. If you followed the instructions that came with it, you would have been told to create your own recovery disk set through a program in the start menu called something like "Create backup disk set"
    If you haven't done it and don't have access to it now, you could either ring the manufacturer and get a replacement recovery CD sent out, or if you can get someone with a original vista CD (not a recovery disk), you can use that and use the OEM license sticker on the bottom of the laptop to install the windows. You will then need to download all the drivers from the manufacturers website for hardware such as sound, graphics, etc...
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by holdensupporter2005 View Post
    Also make sure you dont delete or format the partition with the old windows on it!!
    This way if you need a driver for your ethernet or wlan to work you can navigate to the system drivers folder and recover the network driver.
    Otherwise your up s**ts creek unless you can get drivers from someone else whose on the net to burn you a copy of the drivers. (unless it uses windows drivers for network)
  1. VH - Vapour Recovery Lines
    By monkeyrelish in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-11-2007, 04:44 PM
  2. Stolen Recovery Help
    By Secki in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2007, 05:41 PM
  3. system for ute
    By hbdvysute in forum Car Audio
    Last Post: 30-04-2006, 10:17 PM
  4. System set up????
    By Jarro_sparrow in forum Car Audio
    Last Post: 17-08-2005, 05:38 PM
  5. Fuel Vapour Recovery (carbon) Canisters
    By jules in forum General
    Last Post: 22-01-2004, 04:57 PM
