Results 1 to 20 of 20
Thread: motherboard
    Dec 2007
    Default motherboard
    hi guys probably should search first but need a quick answer.
    following the motherboard i asked before, when i turn the computer on sometimes the bios wont come up but theres power going through the board, sometimes i wriggle the memory strip and then sometimes i swap it and the bios comes up.
    also sometimes i unplug the computer and wait and try again later it finally works.
    what could the problem be, board/cpu/memory strip.
    want to know so i can decide on fixing that board up that my mate gave me to try out or buy new board/cpu/ram and start again.
    its a p4 2.8 gig.
    whats the best way to make more than one memory strip work together as i sometimes put 2 in and it doesnt work but i unplug the 2nd one and it sometimes works.
    need to know as soon as possible
    thanks
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Oh how you bring a smile to my face
    regarding the RAM, did you read the other thread you posted? The RAM has to be matching, you cant go putting two different sticks in.
    Regarding your mobo, its more then most likely something on the mobo itself, and not worth the hassle of fixing. Mobo's are cheap and easy to replace, trying to fix one is a prick of a job, timely and still only a chance it will work.
    You will most likely need a LGA775 Chipset motherboard, which can be had for 40 od bux.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by shonky12 View Post
    its a p4 2.8 gig.
    thanks
    You may have one of those three phase computers. Take it to a factory and plug it into 400v. That should fix it.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    It should fix shonky12, too.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Sounds like a dirty ram slot to me.
    If the bios comes up when you wriggle the ram then thats the problem. Its either dirty or loose. If its a loose ram slot then your best to buy a new board.
    As for the ram not working when you install two sticks... It has to be the same type of ram (not matching as such)
    If its DDR2 667 then you will need two ddr2 667 sticks (doesnt matter how many meg the sticks are)
    eg, 2 x 512mb DDR2/667 or 1 x 256mb DDR2/667 and 1 x 512mb DDR2/667 will work.
    But if one sticks DDR2/533 and the others DDR2/667 they wont work together.
    has to be the same type not size
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by goVZ View Post
    awww now your teasing me....
    Reaper
    Reapers Black VP SS
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Ozzie View Post
    Are you sure? I was always taught it had to be the same size if going in the same channel, never bothered to actually test it though, but after cert III, and IV plus an advanced hardware and networking I just assumed they were right.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by Tom_1569 View Post
    Dead sure mate put it to the test.. Windows will read whatever ram is in it aslong as its the same mhz
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Yeah Ill give it a run, caus you've got me curious... Not doubting what your saying, caus seriously TAFE are far from accurate teachers, but I have to learn there way to get a piece of paper
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    LOL i'd do the same thing to get a cert... just agree with what they say lol
    But working for Centre Com building systems is where I learnt most aspects.
    Fr3ak+--'s Avatar
    Fr3ak+-- is offline Closed On Monday
    Vt Exec 5 Speed
    Jul 2006
    Kingswood, Nsw
    in my pc at work i have 1 256mb stick and 1 1gb stick of pc3200 and it runs fine
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    its a p4 2.8 gig.
    thanks
    Could be a few problems...
    Firstly, if you have the 2 memory sticks set up in a dual DDR configuration, they should be the same type of stick If not, this could be your problem. If you put them both in without dual configuration, then they should work fine even if their different.
    Second, they may not work together because of old bios. Bios updates can fix problems with memory, so it might be worth updating it if it's outdated.
    I would say it's either your motherboard, ram or old bios. Highly doubt your CPU is faulty.
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Just like I said in previous thread
    865gdmp motherboard questions
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by holdensupporter2005 View Post
    You type to fast for Shonky to comprehend.
    S h o n k y , H e r e i s h i n t , m o v e y o u r h e a d s l ow l y t o t h e r i g h t w h e n r e a d i n g a n d y o u w i l l b e a b l e t o r e a d s l o w e r , a n d m a y e v e n t a k e i n w h a t p e o p l e a r e t e l l i n g y o u .
  15. #15
    DavidPartay's Avatar
    DavidPartay is offline somewhat awesome
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    You can use different speed RAM. The computer will just run it at the speed of the slowest RAM.
    You *can* experience some conflicts between different brands and models but 99% of the time you can run different speeds.
  16. #16
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    ok so what if he had registered ram? then hes up s**ts creek
    but I would say the problem lies in a loose ram slot on the motherboard side..
    check the diodes on the m/b to see if their poppin out too. sometimes funny stuff hapens when they do
  17. #17
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    I never really saw the point in buying registered ram for even a high-end gaming PC.
    I just don't see that the price would be worth any benefit you may or may not get.
  18. #18
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by DavidPartay View Post
    Nah registered ecc ram is specially designed for servers mate. 99.99% of gaming motherboards wont take ecc ram.
    Some motherboards (mainly server) run ecc (registered) ram.
    Most just run non ecc
    If you try to run non ecc ram in a ecc slot it just wont go.
    Same if you try to run ecc ram in a non ecc ram board.
  19. #19
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    It's been a few years since I looked into it (for obvious reasons) but I'm pretty sure some of the REALLY older motherboards I used to work with (early pentiums) would have BIOS options to specify if you were using ECC or not.
    But as I've never really paid attention to it so I could be wrong .
  20. #20
    VK
    Jul 2004
    agreed.. in my old old pc i have 768mb of sdram taking up 4 slots.. all different speeds and different sizes
  1. 865gdmp motherboard questions
    By shonky12 in forum The LAN Lounge
    Last Post: 21-10-2008, 10:26 AM
  2. AMD 64bit motherboard brand new ebay need to sell!!
    By ucwepn in forum Parts And Other Items For Sale
    Last Post: 19-10-2005, 03:10 AM
