I'm having a problem with my computer not running USB2.0, i've just done a full format and reinstall and finished all windows updates. I just connected a External HDD to this computer and it tells me there is no USB2.0 High Speed ports, only USB1.1.
I can post up most info just let me know what you need.
Mainboard : Asus A7V-VE
Chipset : VIA Apollo KLE133 (VT8361)
Processor : AMD Athlon XP @ 2000 MHz
Physical Memory : 512 MB (1 x 512 SDRAM )
Video Card : VIA Tech VT8361/VT8601 Graphics Controller
Hard Disk : ST340014A (40 GB)
CD-Rom Drive : SAMSUNG CD-R/RW SW-252B
Network Card : Realtek Semiconductor RT8139 (A/B/C/810x/8x/C+) Fast Ethernet Adapter
Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 3
DirectX : Version 9.0c
I couldnt find your exact motherboard in ASUS's range.
But the closest thing was Asus A7V-E, not sure if you mis-spelt it or ASUS just dont list yours that I can see.
Anyway for the motherboard I mentioned there is a common problem with USB 2.0 not working with XP SP3, but there is a patch available from the ASUS website, cant direct link you.
ASUS DOWNLOAD/SUPPORT
Your motherboard has to have USB 2.0 chips built onto it to support USB 2.0.
Your motherboard is a very old board suggesting that it may only support USB 1.1.
Your best option is to purchase a 4 Port USB 2.0 PCI Card which will give you 4 ports
at the back and sometimes a port on the back of the card for plugging in front panel usb.
Then just disable the onboard USB ports and use the ones from the card.
Unfortunately because it is an actual chip on the motherboard not software or drivers it cannot be upgraded to USB 2.0
The Manual for you motherboard is here Manual Asus A7V-VE
Kind Regards
Holdensupporter2005![]()
CHECK OUT MY RIDE
IF I WAS HELPFUL TOO YOU CLICK MY SCALES
"Girls are like domain names, all the good ones are taken."
