Results 1 to 16 of 16
Thread: Data recovery
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Default Data recovery
    I've got a few problems with a 2nd computer. It's a few years old and it hasn't been formatted since 2003. It's getting a few bugs and I've backed up most of my stuff, but I've still got a 4.5gb folder I need in the c:\ root.
    Now this computer just shuts itself off out of nowhere, I've tried to burn a DVD but I haven't yet got past about 500mb.
    I changed the power supply but the computer keeps magicly turning itself off.
    I changed the jumpers and put the HD in another computer as a slave and it says it's corrupted, but when I change the jumpers back it boots up just fine.
    Is there any way for me to recover this data?
    Shounak
    Always Right
    My Ride
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Burn yourself a copy of Ultimate Boot CD, put the drive in another system, set as master, and another known-good HDD, set as slave, and copy the folder over. Thats what I'd do, anyway.
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    tried mounting the hdd on a usb >ide adaptor, from memory jumper switching isn't needed for that.
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    did u try disconnecting the dvd drive in the other computer plug your hdd in there and do it that way
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by pow3rslave View Post
    Agreed, that's all I do whenever I have a drive that's playing up these days.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Theres nearly allways a way to get the data off, but to what extent you want to go is another case.
    The USB-IDE/SATA is the best option, running as a slave/secondary should work but doesnt always, many reasons why it may not, but I've just finished my working week so I cbf'd to explain
    If you have the USB adapter and it doesnt work running a bootable PE enviroment and backing up that way can some times work to.
    Unless the hard drive is actually failed in some way then there is no reason why the above shouldnt work.
    If you have any problems, feel free to shoot me a PM, as I do this day in and day out for work. And if you get really stuck I'd be happy to do it for you and post it all back, as Im now on holidays
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Shounak's Avatar
    Apr 2005
    Thanks guys. I just ordered a USB-IDE cable of the internet and will be doing it soon. What a bloody handy cable, I never knew such a genius device existed. It'll make backing my laptop up simple.
    I'll tell you how I go. Thanks for that Tom. Hopefully all goes to plan.
    Shounak
    Always Right
    My Ride
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Quote Originally Posted by Tom_1569 View Post
    my mate runs a pc business, and this couple came in requesting data recovery from a dead hard drive, apparently would have cost nearly 200k to get the data recovered by a company in sydney that specialises in such requests. if your hard drive is wiped because u have illict porn that was once on there, it can be recovered as well as a fire damaged h/d.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Zuicider View Post
    200K??? Seems Im under charging people by hmmmm 199,934 bux.
    We over a mid range of data recovery options, we draw the line of having to pull the drive apart and replicate it into another one, as its to risky, and a prick of a job.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by Shounak View Post
    yeah there are a couple of mobs doing them, i got one that has 3 heads on one end (sata, ide and laptop) and a usb cable out of that. mine didn't come with a power supply for the drive, but you only need that for sata and ide, laptop drives don't draw enough power.
    it's all good though, i just use an internal power connector from my pc.
    Shounak's Avatar
    Apr 2005
    Laptop drives? I've never once opened my laptop.
    This one has 2 IDE's and a Sata. No power connector, but I've got plenty of spare power things in my computer.
    Shounak
    Always Right
    My Ride
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    There are companies who do data forensics, and it's f#@$ing amazing what they can do, fire, water, even magnetically damaged drives can often be recovered.
    $200k is on the pricey side, but generally they will charge a mint because some corporate data is priceless.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    I think it's the same one I'm thinking of. It'll actually be a lappy hdd connector, but it's still technically IDE, just with 44 pins instead of the usual 40, also I think ks marginally smaller.
    Last edited by pow3rslave; 12-12-2008 at 12:01 AM. Reason: forgot how many pins in pappy IDE
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Turns out i'm under charging people by 200K then! Damn me and my good will. I even do memory sticks!
    If the USB trick dont work, try a bootable CD with a GUI version of Linux on it (theres quite a few which are really friendly with Windows partitions).
  15. #15
    Shounak's Avatar
    Apr 2005
    Ok. USB trick didn't work. I ordered the cable off eBay, plugged in the power adapter and set the jumpers to CS. I tried it with all the variations of jumpers with no result.
    At first when I plugged it in, it recognises a USB-IDE cable and installs the software and it gives me the safe to eject thing at the bottom.
    But no new hard drive appears like it would with a USB.
    The weird part is that I've got a backup drive which I connected normally with IDE and it registered just fine as a slave (there's no OS or anything on it, just directories). It won't recognise the drive with the USB cable.
    Could it be a faulty cable?
    Shounak
    Always Right
    My Ride
  16. #16
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Possibly the cable.
    It sounds like what mine does sometimes, it boots and detects the drive, but the drive doesnt appear in My Computer. I found that if I plug the USB in quickly after the drive boots up it works, but I have a seperate Power supply and not using the computers.
    Also I never leave a jumper pin on, never tryed it with one on so not sure if thats your problem.
  1. System Recovery
    By r_i_d_a_h in forum The LAN Lounge
    Last Post: 13-10-2008, 10:51 AM
  2. sid - data in sid file
    By aldarn in forum ASR Audio & Electronics
    Last Post: 18-01-2008, 07:51 PM
  3. VH - Vapour Recovery Lines
    By monkeyrelish in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-11-2007, 04:44 PM
  4. Stolen Recovery Help
    By Secki in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2007, 05:41 PM
  5. Fuel Vapour Recovery (carbon) Canisters
    By jules in forum General
    Last Post: 22-01-2004, 04:57 PM
