Results 1 to 11 of 11
Thread: Connecting PS3 to internet
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default Connecting PS3 to internet
    I am pretty daft when it comes to these things...
    I've got the PS3, a length of cat5 connected to the back and run to the EXT2 on my router... and the PC is connected to the router through EXT1 and is obviously connected to the internet.
    Is it connected right and I just have the PS3 settings wrong... or have I fugged the whole show up?
    VT V8 Calais
    Mar 2007
    Can you see what the settings are on the PS3?
    Compare the ip settings on your pc and the PS3, the only thing that should be different is the IP address.
    On your PC go start, run and type in cmd
    you should get a black prompt, type in ipconfig /all and hit enter ( I am not sure how to get the settings on a PS3, I don't have one). Just compare the settings and the only thing that should be different is the last bit of the ip address.
    If this looks o.k., you may have to setup a port forward on your router for the PS3. If this is the case look here
    Port Forwarding for PS3 Online Games - PS3 - Gaming
    50LTRv8
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    go to setting the internet setting ( forgot real name) and set it up to easy setup > ethernet ( or wired it might say )
    Eureka styles!
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by eurekamad94 View Post
    Tried that... it makes me put all these settings in and when it tries to search for an IP it times out...
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    hmm all u gotta do is plug it in the modem then configure the settings on the sony....make sure ur comp isnt blocking from connecting to it...do a connection test on the sony and see what it comes up with...
    also has ur internet got a user name.password to connect to it... cause u wil probs hav to put that through the sony aswell to connect
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Still no luck... it keeps saying that it can't get an IP address.
    This might sound stupid, but how do I config the router, like dijm8 said.. maybe it is blocking the port (or whatever it is called)
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    all i did when i first set up mine is plug an ethernet cable straight from the adsl2 modem into the ps3 and without doing anything else i was online making my psn profile.
    have you tried plugging it in via the ext1 port instead of ext2 to see if that works?
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Hi guys. I know this is an old thread but i'm also having trouble with this. I'm trying to go wireless and i'm just wondering if i need to load the router set up disc in the ps3 to get it to work?
    I had to do this in my new laptop and was thinking i may need to do the same here as well. Any ideas?
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by juzo View Post
    No you can't use the router setup disk on the PS3. Just follow through the setup wizard as suggested under the settings menu in the PS3.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    I'm running mine through wireless now.. all I did was find the wireless network, put in the pass key and it worked...
  1. Connecting IPod to my headunit
    By XLR8ing in forum Car Audio
    Last Post: 04-08-2008, 03:11 PM
  2. connecting strereo in a 97 vs?
    By samboi17 in forum Car Audio
    Last Post: 31-07-2008, 08:06 PM
  3. Connecting Fog Lights on a VT S
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2008, 06:41 PM
  4. sparking when connecting battery
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 05:53 PM
  5. Dis-connecting immobiliser
    By Just_Ice in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 06:41 AM
