Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: wireless help please
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Default wireless help please
    ok we have a wireless router first thing wep is an encryption key isnt it?? second why cant i find my router i cannot find it at all on a wireless set up
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yes WEP/WAP are forms of encryption keys to secure it somewhat.
    Im stating the obvious but you would be suprised how many people do this.
    Have you turned your wireless on? lol, also check that the modem's wireless is on (if applicable). Can you connect via ethernet?
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    ethernet yes i can connect got three connected things connected atm wirless is turned on signal at full strength just cant pick it up
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Is the modem/router and the computer/reciever both running the same frequency.
    802.11a (54 Mbps)
    802.11b (11 Mbps)
    802.11b+ (22 Mbps)
    802.11g (54 Mbps)
    802.11g "Super-G" (108Mbps)
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Some modems (especially telstra's) wont detect/connect to the wireless if its also connected via ethernet, not sure if this is relevent for you, but when trying to connect make sure your not connected via ethernet aswell.
    Also maybe try a power cycle on the modem.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Is the SSID set to hidden? cos i set mine to hidden so ppl cant find my wireless router
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by SAV_117 View Post
    how do u do a power cycle
    Turn it off for 30 seconds, turn it back on, give it time to load and crap then try and find it.
    Quote Originally Posted by trayner View Post
    Good point, which also makes me think of another possibility, some routers are "secured" so you need the disc to connect to, a big pain in the ass if you ask me. What brand and model of router are you using?
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    ohhh ive done the power cycle, nope deffinetly not hidden i have a i connect access
    624w wireless
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    624w wireless
    Ahhh good old iconnect , not the best router imo but it should still be connecting fine. Log into the router, and check the "wireless" settings, even take a screen shot and post it up.
    To log into the router the IP address (using URL bar on browser) for iconnect is normally http://192.168.1.254 and the password is written on the bottom of the router, or try admin/admin or root/root.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    all done dude ive checked all of that
    hmmmm, have you got the latest drivers for your wireless in your computer, latest firmware for router (I dont recommend upgrading this just yet, because it should be unrelated).
    Have you got another computer you can try with? or even an external wireless card/dongle to try. I assume your using the internal wireless?
  15. #15
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    external just bought an external one im picking up the neighbours but not mine my bro cant pick up ours with the ds either. didnt think i would need to update the drivers as the standard drivers should do it
  16. #16
    MudBlood's Avatar
    MudBlood is offline Insert Cool Title Here
    1991 VN S-Pack
    May 2008
    Hahndorf, SA
    Just do what i do and use the neighbours connection..
    If you're SSID is set to display, you have the key correct, do you have DHCP turned on in teh router or trying to use a static IP for the wireless adapter?
    Are you getting any error messages when you try to connect like ip conflict? limited or no connectivity, continual searching for IP??
    if it does seem to connect, can you go to the properties for the wireless adapter and look at the IP address it is given?
    Does your router see the wireless adapter in the client filter, if your router has one of these.
    hope that makes sense as im on hold on the phone here at work while typing it out.
  17. #17
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    haha well cant use the neighbours thats encrypted lol ill check the DHCP but everythin is turned on ive check and checked and my other comp the one im trying to access the internet on doesnt pick my router up at all
  18. #18
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    DHCP Might hold your answer, another thought just came to mind. If you have connected via Ethernet, then DHCP will give you an IP address, so when you go to connect via wireless it might be trying to assign you one when you've already got one. Reboot both, without ethernet plugged in, and give it a whirl. I still doubt this, but im trying to think outside the box cause it doesnt seem to be like most wireless problems.
  19. #19
    SAV_117's Avatar
    VY Lumina
    Jul 2008
  20. #20
    SAV_117's Avatar
    VY Lumina
    Jul 2008
  21. #21
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    thanks tom for all ya help pitty we couldnt get it goin but stuff it im going to buy a new one
    No problems, Im sure there is something that we have both missed. Assuming its a modem supplied by your ISP, give them a ring, im sure after being on hold for an hour, a few transfers, and broken english they should be able to sort you out.
    If your going to buy a new one, I recommend Linksys(owned by Cisco), very well priced, and just an excellent product. Used alot in corporate enviroments.
  22. #22
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    yeah ill give em a ring first and yeah i was gonna check otu linksys cause i seem to pick them up when im looken for a connection hahaa they must be good lol
  23. #23
    MudBlood's Avatar
    1991 VN S-Pack
    May 2008
    Hahndorf, SA
    Quote Originally Posted by Tom_1569 View Post
    Nah IP addresses are assigned per adapters MAC address, if the DHCP range will permit it then you can have 2 IP addresses and effectively have a network bridge. But I have been proven wrong before..
    Could also be bung hardware?
    Another thought just popped into mind, can you connect easily if you remove the WEP/WPA key you are using? effectively making it free to air so anyone can use,, if this works, quickly think up a new key and turn the protection back on.
    As Tom said, if you do get a new router grab a Linksys, Netgear or Billion, I use all these in different offices we have and have found them to be the most reliable.
    Good Luck..
    Muddy.
  24. #24
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    i cant actually see my wireless like i cant select it, it doesnt pick it up its like its not there
  25. #25
    MudBlood's Avatar
    1991 VN S-Pack
    May 2008
    Hahndorf, SA
    Ok,, Try grabbing the latest drivers for the wireless adapter.
    It's been a while for me (a few laptops ago) but IIRC when I was using my old external adapter it didnt support the WEP encryption only the WPA (or the other way around) I ended up switching to the other encryption and using that until I got the new drivers. always pays to have the latest of all.
    I'd also vote for a hidden/blocked SSID (wireless name broadcasting) from your router, or bung router. Pitty you're not in the Adelaide hills you could pop into any of the streets around me and try connecting to many different houses to eliminate the USB adapter.
  1. need wireless AP help
    By pow3rslave in forum The LAN Lounge
    Last Post: 09-10-2008, 07:56 PM
  2. Wireless networks
    By DANNY8 in forum The LAN Lounge
    Last Post: 06-07-2008, 09:22 PM
  3. wireless networking
    By shonky12 in forum The Pub
    Last Post: 09-01-2008, 01:40 PM
  4. wireless broadband
    Last Post: 20-12-2007, 08:15 AM
  5. Anyone use 'Wireless' BB?
    By NORTI in forum The Pub
    Last Post: 12-12-2007, 06:48 PM
