Results 1 to 13 of 13
Thread: Is this comp anygood for me?
    maginoodle's Avatar
    maginoodle is online now Donating Member
    vy series2 ss crewman
    Apr 2006
    Default Is this comp anygood for me?
    Hi, i am thinking about getting a new comp(well new for me). I will mostly use it to websurf and use a couple of programs like dvdshrink and decrypter. These are the specs
    HEWLETT-PACKARD, HP COMPAQ DC7100 SFF(DX878AV) DESKTOP, BLACK, 1 X INTEL(R) PENTIUM(R) 4 CPU 3.20GHZ 3.20, 1024MB, 40 SPEED 40 SPEED HP DVD WRITER 400, 0 KBMB 82915G INTEGRATED GRAPHICS CONTROLLER, NO OPERATING SYSTEM, NETXTREME BCM5751 GIGABIT ETHERNET PCI EXPRESS, ONBOARD SOUND CARD, FDD, 4 USB PORTS, 1 FIREWIRE PORTS, KB, MOUSE, POWER CORDS, HARD DRIVE REMOVED, MINOR SCRATCHES ON CASE
    sorry about the caps but thats how it is advertised.
    Also what would it be worth landed at home?
    I know it has no os but i have been thinking about trying out linux annd i also have a fresh xp pro coa to use.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    VK
    Jul 2004
    200 bucks maybe? However it'd prob suit your needs, and definitely plenty to run linux on.
    MudBlood's Avatar
    MudBlood is offline Insert Cool Title Here
    1991 VN S-Pack
    May 2008
    Hahndorf, SA
    yeah as bezz said $200 tops..
    also seeming as though its a p4 3.2 it most likely will have Hyper Threading (virtual second CPU Core), check it has a monitor icon where there isnt a spot to plug it in on the back, then if need be you have the option of upgrading the graphics at a later stage for that little more guts.
    maginoodle's Avatar
    Apr 2006
    Hi all, i paid 140 delivered. It has a xp coa on it so thats a bonus. Went to put a hd in but i havent seen these conectors before. What hd do i need to get?
    Cheers Shane
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by maginoodle View Post
    Cheers Shane
    They're SATA connectors so when u buy your HD make sure its SATA not IDE
    maginoodle's Avatar
    Apr 2006
    maginoodle's Avatar
    Apr 2006
    Hi all, i got a 160gig hd and put in. I then installed xp, with ethernet cable hooked up.
    I then went to go on the net but couldnt. So i set the ip adress to the correct ones(i have swaped the cable from this comp and used this comps adress).
    I set the connection to show if its connected. It says its connected at 400mbps.
    I then tried to repair the connection. It came up with" failed to query TCP/IP settings of the connection.Cannot proceed."
    I havent come accross this before.
    I always seem to have problems with new net connetions,or after formatting. I have done everything that was ever necessary before. I have been told that my modem is the reason that auto detect settings doesnt work. Cant think of the brand of modem atm i am in my shed.
    Any help appreciated.
    Cheers Shane
    maginoodle's Avatar
    Apr 2006
    An update, i have been googling my problem. One site says
    If all you have is "1394 connection", then you haven't installed your motherboard and/or network drivers.
    . This is what i have.
    How do i work out what drivers i need? I just got this comp and dont know exactly what is in it. I might try and transfer everest onto it and run that.
    cheers shane
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    HP Compaq dc7100 Small Form Factor PC- Download drivers and software - HP Business Support Center
    It'll be the "Broadcom NetXtreme Gigabit Drivers for Microsoft Windows XP/2000".
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    maginoodle's Avatar
    Apr 2006
    thanks govz.
    thats a exe. file, so i assume i just transfer it onto the comp and run it? then everything should be all good.
    i always forget to look at the pc manufactures site, i always go to the manufacturer of the piece ie broadcom in this case.
    cheers shane
    Apr 2004
    Dee Why, NSW
    Yeah, put it on a USB drive or whatever, and just run it.
    maginoodle's Avatar
    Apr 2006
    thanks again govz. i am typing this on my new comp. now just gotta redo all my setting and install firefox and all the other usuall things.
    cheers shane
    Apr 2004
    Dee Why, NSW
    Good to hear!
  1. Are ultratune anygood?
    By beefcream in forum General
    Last Post: 21-10-2010, 03:04 AM
  2. can someone tell me if this is anygood
    By SAV_117 in forum Car Audio
    Last Post: 01-03-2009, 03:25 PM
  3. What is std comp for a 5.0
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2008, 11:09 PM
  4. Strange trip comp chimes and comp error code
    By Jasiel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 11:25 PM
  5. Would a CA18DET be anygood in a VH ?
    By gemini in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 06:47 PM
