Results 1 to 11 of 11
Thread: ghosting (linux dd-ing) xp partition, will it work?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Default ghosting (linux dd-ing) xp partition, will it work?
    my windows disk is chirping like a p plater in a vn, so i thought i'd pull it out and replace it with another hdd i have handy. the one being pulled out is 500gb, the one going in is 250gb, but the xp partition on both is 20gb.
    i was just going to use a bootable linux usb stick i have and DD from one to the other. then i guess i'd have to mark it as bootable. the new disk will be on the same sata socket as the old one, and it should still show up as c:\.
    are there any issues i'd run into with this, i just cbf'd finding new versions of all the apps i have installed.
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    try downloading ghost2003.exe to a bootable floppy and then just ghost it across to the other drive.
    It works fine. I just used it Today on going from a 200gb sata to a 160gb sata.
    http://forums.justcommodores.com.au/signaturepics/sigpic17276_1.gif
    CHECK OUT MY RIDE
    IF I WAS HELPFUL TOO YOU CLICK MY SCALES
    "Girls are like domain names, all the good ones are taken."
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    is that norton ghost? if it is i'm not eager to use it, last time i tried was when my root drive was set to e:\. it got stuck in an infinite loop looking for windows on c:\ and i coultn't boot to anything else
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    Hey mate, how'd you go with this?
    I wouldn't expect there to be too many issues. So long as your boot.ini looks okay, you should be laughing.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    still planning to do it, but i forgot the hdd bays are in front of the southbridge which has a massive stack of passive cooling heat syncs on it, so i'll have to take the mobo out it seems.
    i wish i had a swank lian li style case with hdd drawers and screwless removal. this is just an old centurion, so it's just the case walls come off easy.
    VY II S S/C
    Oct 2008
    Liverpool, Sydney
    That would be nice. But those Lian Li cases are extraordinarily expensive!
    I'm currently using the Antec Sonata III 500 which has a very nice concept (probably used before) for the hard drive bays.
    You screw the hard drive into onto a removable bay which has rubber grommets either side of the screw. Not only does it make the hard drives near silent, but it makes adding/removing hard drives a breeze.
    http://bluecouch.com.au/reviews/sonata3/sonata3-6.jpg
    Jun 2005
    my $120 cooler master case has hdd drawers and screwless bays. nice cheap case for me
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    bit of a problem, even though i haven't swapped the disks in the case yet, i pulled the case side off and plugged in the new disk in, booted a live cd of gparted, used gparted not DD to copy the Xp partition, flagged as bootable, all went sweet and so quick i thought it hadn't worked.
    now booting it, it gets grub error 21, which i think is because it is looking for a 2nd ubuntu partition which existed on the old hdd but i'm over for now. this will be just an xp disc, how should i get back to straight xp?
    should i swap the discs back, get into the grub menu and delete everything except the defaulting to windows chainloader, ideally i would remove grub completely
    any suggestions?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    If you have a windows CD, boot off that. Enter the recovery console (press R). Then run:
    Code:
    fixmbr
    That will remove Grub for you and boot straight into Windows! :P
    Also, just my 2 cents. I've never had any problems with Ghost, really good. But maybe because i've got the full ghost suite its easy!
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    ok, the ****around continues, i tried to boot with the install disc to fixmbr on the new disc, needed admin password, couldnt remember it, replugged old disc, booted windows, ran user setting front ctrl panel, changed password, re-DD'd to new disc, this time the dd'd image should have had the admin password i changed.
    plugged new disc back in, XP install disc, entered password. says it's invalid!
    GRRRR
    bout to try this tool
    Ophcrack v3.1.0 Review - Password Recovery Software Review - Ophcrack Live CD ISO Download
    but i don't know it'll work because the grub error might stop it finding the windows install.
    i don't want to freak with the working xp's disks mbr, in case it breaks the install, i'd rather have it as a backup and work with the new disk
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    found it, let it be known that setting your admin password as 'assword' is funny at the time, but there's no way in hell you'll remember it.
    also the tool i linked to in the last post is rad and found 3/5 passwords in 4 minutes
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  2. Partition Software
    By RufusŪ in forum The LAN Lounge
    Last Post: 06-08-2008, 08:12 PM
  3. Linux?
    By Spaced in forum The Pub
    Last Post: 11-03-2008, 09:02 PM
  4. Any linux users here?
    By stocky in forum The Pub
    Last Post: 21-03-2007, 02:15 PM
  5. Linux users...
    By Tasmaniak in forum The Pub
    Last Post: 16-02-2006, 06:06 AM
