Explain MAFless tune
Topcar
Could someone explain to me what a "MAFless" tune is please?
Thanks in advance,
Topcar
minux
2017 SSV Redline
It is simply a tune that has no MAF(Mass Air Flow (Meter) , handy for when you are using an OTRCAI. Pick up around 10 rwkw depending on the hardness of the tune.
Topcar
Thanks for your reply minux. When you say "no MAF", do you mean the MAF sensor is disconnected for the tune or the vehicle has no such sensor fitted?
Topcar
minux
2017 SSV Redline
Topcar
It is completley removed, thus making the vehicle illegal technically speaking :)
minux
2017 SSV Redline
ringram said:
HSV 300KW GTS's come Mafless from the factory.
There were other mods wich made them ADR compliant though.
ringram
efilive evangalist
55
Sunny London, UK
www.efilive.eu
2007 HSV CLubsport R8 M6
Ive seen the tune, so I know there is no rocket science there. Im aware cam and heads are slightly different, though I wouldnt imagine too much else was changed. I would have thought a mafless tune would pass all emissions requirements. Unless one of those reqirements was that the vehicle cant be modified from stock, in which case any car with headers would fail.
Do you know what mods were required to be compliant?
minux
2017 SSV Redline
Off the top of my head no. However any car with a MAF must have the MAF to be roadworthy and to pass emissions. Removing the move makes you unroadworthy and EPA will have a blast if they want to.
ringram
efilive evangalist
55
Sunny London, UK
www.efilive.eu
Ok cool. Just gut the maf leave it in, but disconnected, or connected, but disabled in PCM. Nobody will be any the wiser.
OLS108
MR Helpful
40
QLD
Stockish VX Berlina
the reason for removing the Maf is because of the restriction it causes
