Raptor VLSX SC sytem
Raptorsc
RAPTR6
Cairns Qld Australia
www.raptorsc.com.au
Hilux 4.0 V6 SC 400kw
For the LS1 people here
Raptor have a LS1 kit on the go, for pictures and information check out the Raptor website and image gallery
http://www.raptorsc.com.au/kits.php?id=19
Current Status on kits,
1. 7.5 psi non intercooled
2. 10.0 psi non intercooled
3. 10.0psi intercooled (still to come)
4. 10.0psi intercooled with heads, cam, intake options
If you would like to talk with someone about this stuff, call Tim @ LS1 Proformance on 07 4951 0433
Raptorsc
RAPTR6
www.raptorsc.com.au
List of goodies
1. Set of 8 36lb injectors
2. Bracketless supercharger mounting system (supercharger integral)
3. MAFLESS tune
4. Polish alloy 100mm intake tubing with filter outside engine bay
5. 8 rib serpentine belt
6. Serpentine belt auto tensioner
7. New additional 6061 T6 Alloy pulley for Power steer pump shaft
8. K&N filter
9. Silicon hose from SC to throttle body
10. System adjusted for 7.5 - 8psi
11. Being a DIDO option at the moment the 2 Bar tuning is included.
Other notes, the Raptor system should be complimented with extractors and a free flowing exhaust system for maximum output and efficiency.
Drive in drive out same day.
vxchev
S/E Melbourne
VX2 CALAIS V8
Thanks Raptorsc.
I suppose you'll also need to upgrade the valve springs. Is the stock fuel pump okay or do you recommend it be upgraded, also are the injectors new or reconditioned.
Do you have any dyno results or track times yet.
You certainly made it easy with the DIDO option, how far away is the 10.0psi intercooled kit.
